30k Maintenance requirements?
Discussion in '4 Cylinder' started by Juggernaut, Dec 22, 2012.
  1. Dec 22, 2012 at 10:52 AM
    Juggernaut
    Juggernaut [OP] Captain
    Sacramento
    25 TRD OffRoad DCSB
    I'm coming up to 30k on my truck and after reading the forums I was a little confused as to what fluids I need to change. I have a 2010 4 cyl manual prerunner.
    Looking at the book it looks like the only things I need to do is the standard oil / air filter change, is this correct? Do I ever have to change out any other fluids? The only variation from this that I can see that applies to my truck is at 120k I need to change out the spark plugs.
    Just want to make sure there is not anything else I should do to maintain the truck.
  2. Dec 22, 2012 at 11:06 AM
    Jared
    Jared A Bad Ass Member
    Jared
    Porterville, Ca
    2011 Toyota Tacoma DCAB LBED 4WD
    Current Mods: -Viper Alarm System -Covered up seat belt buzzer -WeatherTech Floor Mats -Fog lights turn on with Bright Lights -17 inch Chrome Tacoma rims (off a 2012) -Line-x'd the front skid plate -USB charger that plays music via Mediabridge -Window Tint: Front-20%, Back-5% -Front Toyota License plate logo -2 Extra D Rings in front -Bright Reverse Light Bulbs -6,000K Head light bulb -6,000K Fog light bulb -LED Dome & MAP light bulbs -Trailer brake controller -Escort 9500 Radar Detector (hardwired) -BendMount Mirror Radar mount -C.B. Radio with a built in Mic Plug in by Aux -LED Bed lights with an extra fog light switch -30 inch LED light bar under front grill wired to an extra fog light switch
    I have a 4.0 V-6 and am wondering the same... :popcorn:
  3. Dec 22, 2012 at 7:18 PM
    slo13zx3
    slo13zx3 Well-Known Member
    Brian
    forest city pa
    14 trd off 6speed nav
    front dif rear dif trans transfer case oil only if u want to i have some trucks in my fleet with 300k never been done
  4. Dec 23, 2012 at 12:19 AM
    Juggernaut
    Sacramento
    25 TRD OffRoad DCSB
    Im 2wd. I don't think I have a front diff/transfer case.
  5. Dec 23, 2012 at 12:21 AM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Nope, you sure don't. Do the rear diff and cabin filter, spark plugs, aaaand I think that's the biggies.
  6. Dec 23, 2012 at 10:07 AM
    Juggernaut
    Sacramento
    25 TRD OffRoad DCSB
    How often should I replace the rear diff oil, I don't see it in the book. Is there some type of synthetic I can replace it with and then forget about it for awhile?
  7. Dec 23, 2012 at 10:33 AM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    My 2010 maintenance guide (page 41) shows "replace rear differential oil ( prerunner & 4WD vehicles with optional limited slip differential only)." This is following the normal use schedule.
  8. Dec 23, 2012 at 10:41 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Maintenance requirements and intervals are listed in your warranty and maintenance guide that came with your truck when you bought it, fellas.
    Here's a copy incase you can't find yours...
    http://www.toyota.com/t3Portal/document/omms/T-MMS-10Tacoma/pdf/2010_Tacoma_WMG_lr.pdf
    30,000 miles
    Lubricate propeller shaft (4WD)
    Re-torque propeller shaft bolt
    Replace engine air filter
    Replace engine oil and oil filter
    Replace rear differential oil (Prerunner and 4WD vehicles with optional limited slip differential only)
    Replace spark plugs (1GR-FE engine only)
    Rotate tires
    Check the following
    Ball joints and dust covers
    Brake lines and hoses
    Brake linings/drums and brake pads/discs
    Rear differential oil (except Prerunner and
    Steering gear box Steering linkage and boots
    Fuel tank cap gasket
    Radiator and condenser
    Drive shaft boots (4WD)
    Engine coolant
    Exhaust pipes and mountings
    Front differential oil (4WD)
    Fuel lines and connections, fuel tank band
    Transfer case oil (4WD)
    and fuel tank vapor vent system hoses
    Driving on dirt roads or dusty roads:
    Tighten nuts and bolts on chassis and body
    Driving while towing:
    Replace front differential oil (4WD)
    Replace manual transmission oil
  9. Dec 23, 2012 at 11:30 AM
    Juggernaut
    Sacramento
    25 TRD OffRoad DCSB
    So I guess I only have to do the stuff in bold. Just cant believe its that simple. Thanks guys.
  10. Jan 28, 2013 at 8:08 AM
    SouthernTaco
    SouthernTaco Well-Known Member
    Scott
    Jasper, GA
    '10 PreRunner SR5 4-banger AC
    I have a 2010 Prerunner with Limited Slip Differential.
    As part of maintaining my warranty I had to have the rear diff oil changed at 30,000.
  11. Jan 28, 2013 at 8:14 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Who told you that?? You don't have a mechanical limited slip differential unless you swapped it in yourself. You have an open differential and the manual never says when to change it, just says inspect. I held out until 40k miles with my differentials and transfer case fluids.
  12. Jan 28, 2013 at 12:11 PM
    SouthernTaco
    Scott
    Jasper, GA
    Pugga - The stealership told me I had to.
    First they told me I had a mechanical limited slip differential. I said it was an auto, then they agreed. Still said the fluid change and flush was required to maintain original factory warranty.
    It cost me $154.12.
