30k mile maintenance
Discussion in 'Performance and Tuning' started by tacodave13, Mar 18, 2015.
  1. Mar 18, 2015 at 2:25 PM
    tacodave13
    tacodave13 [OP] Member
    Dave
    Charlotte, NC
    13 PreRunner SR5
    Closing in on 30,000 miles.... any maintenance recommendations? To date I haven't done much other than a few oil changes (synthetic), tire rotations, and cleaning the air filter (aFe pro dry).
    Thanks
    2013 Prerunner 2.7L 4cyl
  2. Mar 18, 2015 at 6:04 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
  3. Mar 31, 2015 at 11:26 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    I would do a drain and refill of trans fluid every 30k, its not that hard, and will help the trans last longer, that stock fluid does not last 100K like some say!!
    You will end up changing about 3 qts, Oh wait is it an automatic?? Thats what I was referring to.....
  4. Mar 31, 2015 at 11:29 AM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    to add what has not been said, also change the rear diff fluid and change the plugs.
  5. Mar 31, 2015 at 4:03 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Toyota changed the 100k marl, lessened it quite a bit
  6. Mar 31, 2015 at 4:12 PM
    Manwithoutaplan
    ID
    I Change my Tranny, Diff and tcase every 30K.
  7. Apr 22, 2015 at 5:39 PM
    calico
    calico Well-Known Member
    Northeast
    13 Tacoma Limited
    Viper Alarm and Remote Start Prestigious Society mod Camera display relocated to headunit Weathertec floor mats, window deflectors, and mud flaps Toyota Bed mat Tailgate lock Undercover SE tonneau and Swing Cases (driver and passenger) Hi-lift install Fumoto Qwik Valve ImMrYo Mirror mod Salex console organizer
  8. Apr 23, 2015 at 11:38 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Like these guys say...
    plugs, trans fluid, diff fluid, brake fluid, power steering fluid, wire wheel and touch up rust on frame... open the front doors and clean the dirt out from behind the rubber seals on the front fenders, the only spot that dirt can build up.....
