30k miles. Fluid swap to synthetic question.
Discussion in 'Performance and Tuning' started by benbacher, Aug 17, 2012.
  1. Aug 17, 2012 at 1:13 AM
    benbacher
    benbacher [OP] Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    So I'd like to swap EVERYTHING over to synthetic, as stated I've got 30,000 miles on the truck. Do I need to do a flush of everything to get the full benefit? Also, what does the dealership charge for doing a full fluids swap? Is it worth it?
  2. Aug 17, 2012 at 4:53 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Honestly i would diy. Its super easy. You can change both your engine oil and diff fluids but leave your trans fluid alone unless you use world standard which is toyota only but is a synthetic. No need for a flush. Dealer would charge around 50 or so bucks plus tax for an engine oil change. I dont know how much for a diff fluid change but it might be more
  3. Aug 17, 2012 at 5:15 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, DIY and leave the transmission on stock fluids. Just drain and refill. Modern synthetics play well with their dino counterparts so no need to do a 'flush'.
    If I had to take an educated guess, I'd guess the dealership will most likely charge in the neighborhood of $100/axle for the differentials.
  4. Aug 17, 2012 at 10:49 AM
    benbacher
    Anchorage, AK
    Well, the 30k service from toyota covered front and rear axles, transfer case, air filter, spark plugs and engine oil......575. Definitely going to do this myself. I need to do the breather mod on my rear dif anyway. Any recommendations on spark plugs? I think royal purple makes differential oil dont they? Never used it before but I've heard good things. Also heard great things about mobil 1 too though...decisions decisions.
  5. Aug 17, 2012 at 10:56 AM
    Pugga
    Massachusetts
    Wholly Sheit!!! $575 :eek:
    Diff/x-fer case oils - $110
    Engine oil - $25
    Oil Filter - $5
    Plugs - $20
    Air filter - $20
    Cabin Air Filter - $10
    Total = $190, call it $250 just for argument's sake. This is why I don't trust dealerships.
    I hope they at least gave you a reach while you got bent over the service counter.
    As far as oils, Mobil makes a good gear oil also. I think I used Valvoline last time I did mine.
  6. Aug 17, 2012 at 10:58 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Dealerships always try and rape people and the bad part is a bunch of people pay for it!! :eek: You can do the 30K service yourself without any issues. Even if you dont do it all at once you can spread it out and take your time.
  7. Aug 17, 2012 at 11:06 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    The price isn't too extreme considering shop labor is over $100/hr pretty much everywhere you go nowadays. The question is how valuable is your time? If you have the time to DIY it then you can save some money.
  8. Aug 17, 2012 at 11:08 AM
    SalemCBR
    SalemCBR Oregon's #2 TW rep
    Oregon
    04 DC Elock PreR
    Deck plate, all time auxillary, black billet, xeon bulbs, sockmonkey decals, and lots of back to black.
    Its not a secret that they make a profit there....
    Yo.
  9. Aug 17, 2012 at 11:14 AM
    Pugga
    Massachusetts
    The price is very extreme... You or I could walk into the dealership and purchase all the parts for around $200. You honestly think it takes them 3 hours and 45 minutes to perform the work?? It doesn't even take me that long and I don't have a lift. If you're proficient, that's a 2 hour process at most.
  10. Aug 17, 2012 at 12:05 PM
    benbacher
    Anchorage, AK
    I can do it all, never done plugs before though. I have a Volant CAI so the stock airbox is gone, and they're right there easy to get to. Shouldn't be too bad. Just gotta find a walkthrough which I'm sure is on here.
  11. Aug 17, 2012 at 12:17 PM
    Pugga
    Massachusetts
    DIY's for most of the 30k mile maintenance is here:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/7174-2nd-gen-tips-mods-more.html
    How to change spark plugs:
    http://www.tacomaworld.com/forum/technical-chat/30479-how-spark-plug-change-1-gr-fe.html
  12. Aug 17, 2012 at 1:58 PM
    benbacher
    Anchorage, AK
    Thanks Mike, much appreciated. Looks like I'll be getting dirty sometime soon. The best part? I finally have an excuse to buy a torque wrench. :)
  13. Aug 17, 2012 at 3:30 PM
    Pugga
    Massachusetts
    Hell yeah! Any excuse to buy tools :thumbsup:
    Remember to keep the oil containers. Most Auto parts stores will take it back and recycle it.
  14. Aug 18, 2012 at 1:47 PM
    benbacher
    Anchorage, AK
    I did not know that.
  15. Aug 18, 2012 at 1:56 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Don't know if it's Fed or State, but in California, any retail establishment that sells more than "X" quarts per week must accept used oil and filters at no charge.
    I think it is an EPA fed law.
    Some will actually pay you if you bring it in "leave there" containers like your old 5-qt oil jugs. I don't bother asking... I'll just walk in with 3 or 4 jugs and dump them into their can. I was leaving them for a while, but Costco had a sale on 6-packs of M1 for $26 so now that I'm back to quart bottles for the next year or two, I need to keep the jugs.
  16. Jan 2, 2013 at 3:32 PM
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    i did my own. used amsoil gear lube in tranny and diff. 5w-30 in motor. easy to do.
