30k Oil Change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by r1200gs4ok, Mar 14, 2019.
  1. Mar 14, 2019 at 12:22 PM
    r1200gs4ok
    r1200gs4ok [OP] Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    Man....i just changed my oil for the first time since the freebies ended.....the first time i did it was at 5000......at that time, the silver button would not come off and the whole canister turned.....no problem, just had lots of oil to deal with......my dealer has done it overtime since.....so, now being at 30k, i am doing everything......boy, i thought it would be simple and wondered if the bottom would still be hard....well, to my surprise, the button unscrewed very easily.....however, I could not get the canister to budge.....i used the toyota filter wrench and my ⅜" drive with a pipe for leverage.....nothing, nada........i also noticed how difficult it was to get the drain plug out.....well, after everything i tried failed, I went and got my 27mm 6pt socket which fits over the ⅜" hole.....using a pipe for leverage, it finally broke loose....i was afraid i was going to break it and not be able to change the filter.....
    I am going to look into the screw-on modification or the metal canister.....i also changed the drain plug out for the Fumoto valve.....the hardest thing, or should i say most annoying thing, is taking off the skid plate....but had fun.....also change cabin filter and engine filter.....love this truck.....
    My next thing is to bleed the brakes.....i read or saw something that said if i have ABS, to disconnect the battery????.....is that right?
  2. Mar 14, 2019 at 12:25 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Sounds like the dealer was making the canister and drain far too tight instead of following the proper torque specs, I have had not issues removing them on my truck.
  3. Mar 14, 2019 at 12:25 PM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    There is no reason to bleed your brakes unless you replaced a leaking cylinder or lines or last if the brake fluid has been contaminated
    whatstcp, Anchovy and r1200gs4ok[OP] like this.
  4. Mar 14, 2019 at 12:27 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^Toyota says to flush brake fluid every 3 years.
    Put some oil on the filter cap threads and you'll be OK. Dealer probably overtorqued it. Wouldn't bother with aluminum cap since aluminum on aluminum threads can gall.
    Don't need to disconnect the battery for brake flush. The ABS unit doesn't have retained power if truck is off.
  5. Mar 14, 2019 at 12:27 PM
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    Why bleed the brakes? Most cars go their entire life on the factory fill of brake fluid.
    I'm not familiar with Toyota ABS, but I have spoke to one of the GM engineers that worked on ABS for fourthgen F-bodies. To properly bleed the ABS unit on them, you either need the dealer tool (Tech2 IIRC), or the work around was to cause an ABS event (lock up the brakes in gravel for example), drive to your shop, do not shut the car off, jack it up, and bleed the brakes. Major PITA. We did that once when switching to Castrol SRF (these cars were being run on a road course). Not something I'd ever do again.
  6. Mar 14, 2019 at 12:28 PM
    r1200gs4ok
    O. K.
    Irvine, Ca
    yea, that was my thought also....with the young guys doing the oil changes i often wonder it they even torque at all......the canister turns till it stops.....that maybe the issue....it could be seizing up due to heat
    shakerhood[QUOTED] likes this.
  7. Mar 14, 2019 at 12:31 PM
    Modesto Tacoma
    central california
    LIMITED 4X4
    At work when I do oil changes there are times I have to use an impact gun loosen the canister sometimes. A lot of people way over tighten them
  8. Mar 14, 2019 at 12:33 PM
    r1200gs4ok
    O. K.
    Irvine, Ca
    wow......i was told to do that with the botton....but just sort of zap it to loosen....but the canister?.....that could have issues with threads couldn't it
  9. Mar 14, 2019 at 12:33 PM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    The first time I unscrewed it, it was tight. Been fine ever since.
    shakerhood and r1200gs4ok[OP] like this.
  10. Mar 14, 2019 at 12:41 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    At 30k I would just suck all of the brake fluid out of the reservoir I can with a mighty vac and refill with fresh. Kindof a "half flush". Do the whole job at 60k.
    r1200gs4ok[OP] and kahanabob like this.
  11. Mar 14, 2019 at 12:44 PM
    Modesto Tacoma
    central california
    LIMITED 4X4
    I have seen other guys Crack it by removing with a breaker bar. Trust me people seriously over tighten them a lot.
  12. Mar 14, 2019 at 1:32 PM
    Woodrow F Call
    Colorful Colorado
    Aree we talking changing the fluid?
    Brake fluid loves water. It just soaks up all the moisture it can. Then the water destroys the insides of your brake system. You might not ever see it unless you put lots of miles on your vehicle.
    r1200gs4ok[OP], Boghog1 and tonered like this.
  13. Mar 14, 2019 at 1:39 PM
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    Do the Baxter Performance adapter and spare yourself grief ever again. Best $200 I ever spent.
    Dacon likes this.
  14. Mar 14, 2019 at 1:42 PM
    shakerhood
    Southern Ohio
    Holy crap thats crazy, dont know why people feel the need to crank down on oil filters and drain plugs.
  15. Mar 14, 2019 at 1:44 PM
    MidCitiesMildMan
    Yes, the fluid. And yes, brake fluid is hygroscopic. However it is in a (mostly) sealed system.
  16. Mar 14, 2019 at 1:55 PM
    Modesto Tacoma
    central california
    LIMITED 4X4
    These young kids are just nit taught the right way to do things.
  17. Mar 14, 2019 at 1:55 PM
    r1200gs4ok
    O. K.
    Irvine, Ca
    thats true...however, if you have a leak some where, no matter how small, there is a chance that air will seep in........air by nature contains moister which is water........water tends to boil at 212F and create air by evaporation.......thats why people get "mushy" brakes.......they have ir in the lines......thus, the reason to replace fluid and bleed
  18. Mar 14, 2019 at 1:59 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    It won’t gall with all that oil residue on it. No one has reported any issues with the aluminum cap upgrade.
  19. Mar 14, 2019 at 2:01 PM
    MidCitiesMildMan
    I'd guess that 99% or more of Tacoma owners never drive hard enough to get the brake fluid to 212º. I am pretty sure the stock pads would fade well before they could transfer that much heat.
    If there is a leak, fix the leak, then bleed. Until then, it is my opinion that the only time one should replace the fluid is if they intend on extreme usage (like road racing).
