30K Service??? How Important?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnson8537, May 24, 2008.
  1. May 27, 2008 at 2:13 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    Yep, that was on my 811.00 bill. :eek:
  2. May 29, 2008 at 8:34 PM
    IM4UH
    IM4UH Member
    Central Texas
    08 Tacoma Prerunner Double Cab
    If you do the work yourself, and especially if you have an extended warranty, I suggest you document recommended service milestones and keep your receipts.
  3. May 30, 2008 at 12:25 AM
    TRDGRL
    TRDGRL My Toys.....
    TRDGRL
    RainForestVille, Honolulu, Hawaii
    '11 BLK Tacoma PreRunner TRD SR5 Access Cab
    See Signature.....
    My sales guy said the same thing.....change the spark plugs at 100K.....and for me I'll never reach a 100K.....at most 5K-6K a year!!!
  4. May 30, 2008 at 5:44 AM
    CutandShootTaco
    CutandShootTaco Member
    My 2004 6-cyl had Iridium or platinum plugs. Are you saying that the 2008's went back to cheap copper plugs?? :confused:
  5. May 30, 2008 at 5:55 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Can you upgrade to the iridiums so that after the 30k your good to 130k?
  6. May 30, 2008 at 3:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    actually.....05 and up went back to copper plugs in the v6. i still dont understand why they did it though.......i figure more or less saving money that way for them.
  7. May 30, 2008 at 3:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yup, and alot of people have done so. i went with the standard coppers though, mainly because of price per plug, plus i really dont mind changing them every 30k, although.....i may go with the iridiums at 60k anyway.
  8. May 30, 2008 at 3:21 PM
    Johnson8537
    Johnson8537 [OP] Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    I talked to my service tech today about teh copper vs iridiums.
    he said in the 05+ he would not reccomend going to the iridiums.
    The reason he gave was the truck was not meant to run and them and the trucks he has done with them have came back in pinging.
    Just due to this i may go with the coppers. If OEM is copped i figure there may be a reason since the technology was already availble and they had used it before.
  9. May 30, 2008 at 3:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    just my opinion, but i think he's just blowing smoke man. the higher compression on the 4.0v6 tacomas has a bit to do with that there. the pinging he is talking about is more than likely due to cheaper gas.......not the plugs. iridiums supposedly spark a little better than the coppers, so i highly doubt what he says about pinging being caused by plugs.
    on the other side.....the coppers are cheaper. relatively easy to change in the v6 too, so go with them. cant go wrong either way, imo.
  10. May 30, 2008 at 5:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I could see him mention them causeing "ping" if they werent iridium plugs. Hotter pugs cant shed heat away from the combustion chamber causing the ping, but, All Iridium plugs are a colder heat range than the factory plugs. I think the Tech. is just an idiot. :)
  11. May 30, 2008 at 5:17 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    me too man!!:D
  12. Jun 2, 2008 at 5:18 AM
    CutandShootTaco
    So at 30K miles if I change to Iridiums, I can let them go for 100k miles? Anyone know the part number for Iridiums for a 2008?? :confused:
  13. Jun 3, 2008 at 5:24 PM
    Johnson8537
    Oregon
    hey guy on the Rear Diff... Since i have the Sport - not Off Road
    I do have a LSD correct?
    Do i need to do my rear diff at 30K? The manual says with LSD.
    So I assume just the SPORTS need it changed at 30K not the Off Roads because they have a Locking rear diff.
    Am i reading this right???
  14. Jun 3, 2008 at 5:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think tha manual calls for all models to be changed at 30,000. For the LSD, you have to use an LSD addative. I change mine at 15,000 miles as I used it hard, and tow a boat. :)
