30's or 31's???
Discussion in '5 Lug' started by slickrick614, Nov 29, 2014.
  1. Nov 29, 2014 at 10:06 AM
    slickrick614
    slickrick614 [OP] Well-Known Member
    Ricky
    wanaque nj
    06 taco 2wd 5spd
    Performance clutch, aero turbine 2525 muffler, 6k hids, 5% tints, smoked tail lights
    I have a 06 2wd 5 lug......can I fit 31x10.5 tires with no lift just wheel spacers???....if not whats biggest tires I can fit with no lift and wheel spacers???
  2. Nov 30, 2014 at 12:25 PM
    SleazyPetey
    SleazyPetey Popeyes > KFC
    Pete
    Northern Virginia, USA
    2013 Regular Cab
    I think without any mods, you can put on 235/75/16's on them.
  3. Dec 4, 2014 at 12:03 PM
    justinh384
    justinh384 Active Member
    Justin
    Wrightsville, GA
    2017 White Toyota Tacoma SR
    You should be able to fit 30 9.50 15 if you remove the black boxes. You can fit 235 75 15 with absolutely no mods. The 235 75 15 are about 28.88 inches tall.
  4. Dec 4, 2014 at 3:57 PM
    jtye
    jtye Well-Known Member
    DC
    08 Super White 5 lug
    Fog lights, fatbob's 5lug lift, Cragar 15x7, 31x10.5 Gen.Grabbers, Wet Okole
    Plenty of threads on this, just search around, but last poster justinh384 is right; 30s without black boxes or 235 75 15 with no mods, just new rubber on your stock wheels. I went 235s and got the fatbobs and went up to 31's within a year, think about it for a bit before you pull the trigger, might save you some dollars in the long run.
