31”s with 3” lift on a 4 banger?
Discussion in '5 Lug' started by lnfravor, Jun 15, 2019.
  1. Jun 15, 2019 at 6:37 PM
    lnfravor
    lnfravor [OP] Active Member
    logan
    2008 2.7L White Tacoma
    3" lift on 31's with bart d trucker wheels
    Got a 2008 2.7L Tacoma. Getting 31” kumhos with a three inch lift put on in a few weeks. Have to get some spacers to clear the calipers. In doing so after it’s done would the truck vibrate because the spacers Will jack the tires about 2 to 3 inches out of the wheel wells. It’s a 5 lug.
    Early B. likes this.
  2. Jun 16, 2019 at 5:07 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    What size spacers are you using? What rims are you using
  3. Jun 16, 2019 at 5:17 AM
    lnfravor
    logan
    15” d truckers from the Bart wheel brand and I’m buying 1” spacers from motor craft tech
  4. Jun 17, 2019 at 6:43 PM
    Early B.
    Early B. Well-Known Member
    Brad
    metro Atlanta
    2014 2.7L, 5 lug Tacoma
    18" tires and rims, 2.75" Procomp lift, Fox shocks in rear.
    I have a 2.7L 5-lug Tacoma with 31.5" Kumhos and a 3" Pro Comp lift. I don't use spacers and there's no rubbing. The only thing I needed to do was delete the black box.
    I would suggest eventually upgrading the rear shocks to Fox 2.0. Do it all at the same time if you can because the stock shocks aren't designed to accommodate a lifted vehicle.
    5 Lug Fury likes this.
