315/70-17 On 07 Tacoma with 3" Lift, Will they fit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SinCity702, Jul 1, 2012.
  1. Jul 1, 2012 at 8:17 PM
    SinCity702
    SinCity702 [OP] New Member
    Fontana,CA
    07 Tacoma PreRunner
    K&N Short Ram Intake Magna Flow Exhaust System Blacked out badges Blacked out headlights Smoked Tail lights 3" Front Leveling Kit ToyTec Top Spaced
    This is my first thread and need some help with this one. I came up on a real good deal to pass. I got some Hankook Dynapro MT 315/70-17 and i would like to know if i can get them to fit on my PreRunner with a 3" Front leveling kit? I have read some cutting is needed and will that effect the durability of the truck its self. Need some good input. The tires were really too good to pass up and still have about 75% tread on them.
  2. Jul 1, 2012 at 8:19 PM
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
    not on stock rims and you will need major cutting/trimming
  3. Jul 1, 2012 at 8:20 PM
    trdNick
    trdNick Odie
    Texas
  4. Jul 1, 2012 at 8:24 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Chances are high you won't want to do all the things involved to run a 315 on a 3" lift. Even with a 1" BL you're still gonna have to cut the shit out the fenders and I wouldn't want anymore BL than 1".
    Check all my posts in the linked thread and my build. DonnoD's build too and search for relenltess Tacos 2nd gen build.
  5. Jul 1, 2012 at 8:26 PM
    300rem7
    300rem7 Well-Known Member
    Arlington, Texas
    2011 TRD Offroad 4x4
    Lots of info. Look under "Common Truck Modifications".
  6. Jul 1, 2012 at 10:16 PM
    SinCity702
    Fontana,CA
    07 Tacoma PreRunner
    Thanks I appreciate all the info. The links really helped. Just looks like I have some cutting to do. I'll post pix when done. And I have Aftermarket wheels too. They don't hit the a arm they just rub a bit on the fender mount.
  7. Jul 1, 2012 at 10:17 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    yep i did it with just body mount chop, removed the pinch weld, and have fiber glass, only rubs at full lock stuffing the tires, mine are actually quite a bit wider than a 315 too
  8. Jul 5, 2012 at 12:52 PM
    SinCity702
    Fontana,CA
    07 Tacoma PreRunner
    Question estimate how much of the body mount did you guys cut off?
