31s with stock gears anyone?
Discussion in '5 Lug' started by 5lugturtle, Apr 6, 2017.
  1. Apr 6, 2017 at 2:10 PM
    5lugturtle
    5lugturtle [OP] Well-Known Member
    Conner
    San Diego
    2012 Silver Tacoma 5 lug regular cab 2x4
    Lift,31s
    How do you guys like it? Im getting around 17-18 mpgs in socal. Thinkimg about downsizing my next tire set.They look good, and have helped me not get stuck in mud/dirt they do there job.
  2. Apr 6, 2017 at 8:02 PM
    Early B.
    Early B. Well-Known Member
    Brad
    metro Atlanta
    2014 2.7L, 5 lug Tacoma
    18" tires and rims, 2.75" Procomp lift, Fox shocks in rear.
    I got 30.5's -- does that count? I'm getting similar gas mileage. Love the look of my tires, so I'll keep them that size, but anything larger is out of the question.
  3. Apr 13, 2017 at 11:59 AM
    deadbeat0321
    deadbeat0321 Member
    So Cal
    2014 RC 4CYL
    rage
    You guys just sold me on not going to 31s without having everything in hand for a re-gear.
  4. Apr 13, 2017 at 12:02 PM
    Clearwater Bill
    Billy
    Largo Florida
    29's (235/75) are as far as I'll go. Stock rims, suspension no rubbing, no regear needed.
  5. Apr 13, 2017 at 3:14 PM
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    I'm running 29.3" on my 5-speed manual. Final drive ratio with the stock 215/70R15 works out to 3.307:1 gearing. Up-sizing, it drops it to an uncorrected effective 3.03:1. To correct, for this small up-size would require 3.61 gearing. In effect, to correct just the conservative up-size from 26.9" OEM to 29.3" 225/75R16's that i have, would require taking the 3.58:1 axle from a 5-lug auto transmission version, and putting it in mine.
    In up-sizing, you are also adding to the issue, with the weight increase of larger tires and/or rims, to a small degree.
    I've been running my tire/rim setup for 2 years - it has advantages and disadvantages. The good - i drive mostly highway (80%?) and once i get up to speed, i am turning lower revs, and holding them for better gas mileage. The bad - i know i am going to be in for an early clutch replacement. I am an aggressively accelerating driver by nature - my other car is a motorcycle. With uncorrected gearing at present, on acceleration away from first - the truck has an effective 0-10km/h acceleration dead-zone that sometimes requires a bit more of revs and clutch slippage than is ideal. If i am being exceptionally lazy, inattentive, or careless with the pedal-work, it'll sometimes cough and stall out, pulling away from a stop... embarrassing...
    29.3" is seriously the maximal i'll go for, without a re-geared setup on the bench and ready to go. I know the latest 5-lug thing seems to be going as large as possible, but there is a cost involved, in all ways.
    Know your tires, know your gears. There is a relationship.
  6. Apr 16, 2017 at 10:56 PM
    5lugturtle
    Conner
    San Diego
    Lift,31s
    Yeah I like the look, but I think ill be trading in these 31s for 235s in another 10k miles. I don't drive to hard or push my trucks limits by any means. I baby the hell out of my truck, but having larger tires does add some more pedal to the medal just to get up hills, that's about it plus the gas mileage, but that's part of the deal with the bigger tires I knew that coming in. I love my truck, but I will most likely be downsizing to the 235s, getting a re-gear is just not a good option for me if I ever plan on selling my baby,because its a two door, and if me the girlfriend ever plan on expanding in numbers I might have to sell it :(. On the plus I most likely will buy a double cab :) . I baby my truck, but even having the bigger tires I gotta slowly push it around 2.3k rpm just to get up those hills, but I have never been past 3k rpm lol I drive slow as fuge. Maybe ill sell these 31 tires to one of the 5 luggers in socal if they want them cheap with around 10- or 15k miles on them haha.
  7. Apr 20, 2017 at 9:17 AM
    SamGoingHam
    SamGoingHam IG: SamGoingHam
    Sam
    Phoenix, Arizona
    2014 TACO 5LUG LOCKED
    33s. Stock gearing. Bitch is slow AF, but I still love it to death. Saving up for 4.56 and a regear.
  8. Jun 27, 2017 at 11:07 PM
    ANDROOO
    ANDROOO Well-Known Member
    Andrew
    PHX to SOCAL to PHX
    2013 Tacoma Reg Cab
    How much ?:boink::hungry:
  9. Feb 12, 2018 at 9:42 AM
    Gary 1024
    Gary 1024 New Member
    Gary
    2005 5 lug
    31's on stock manual transmission, running great on highway but i'll go for 4.10
