32/11.5 tires on 4 cyl
Discussion in '4 Cylinder' started by MikeyD, Sep 14, 2009.
  1. Sep 14, 2009 at 3:26 PM
    MikeyD
    MikeyD [OP] Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    Just curious if anyone on here was running 32/11.5 bfg mud terrain km2's on their 4cyl's. If you do can you post some pics thanks
  2. Sep 14, 2009 at 3:28 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    if your considering changing your tire size that much you might wanna consider changing your gear ratio also
  3. Sep 14, 2009 at 3:39 PM
    MikeyD
    Sayreville NJ
    I wanted a 32/10.5 tire but couldnt find a nice mud tire or all terrain tire in that size with a 15 inch rim. Do you know of any.
  4. Sep 14, 2009 at 3:47 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
  5. Sep 14, 2009 at 3:54 PM
    MikeyD
    Sayreville NJ
    im not going to regear thats why im going with 32's. I was originally going to buy the 255/75/17 bfg mud terrian km's but they only come in 17's so now im stuck and dont know what tire to get. Thats why im looking at the mud terrain km2's 32/11.5
  6. Sep 14, 2009 at 4:09 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    your stock size now is 245/75/16 right?
  7. Sep 14, 2009 at 4:12 PM
    MikeyD
    Sayreville NJ
    Yes it is.
  8. Sep 14, 2009 at 4:19 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
  9. Sep 14, 2009 at 4:41 PM
    MikeyD
    Sayreville NJ
    Wouldn't i have to get spacers though. Or will they fit on a stock rim with no rubbing? And i appreciate your help by the way.
  10. Sep 14, 2009 at 4:57 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    you might have very little rubbing, so you might wanna check out a set of spidertrax
  11. Sep 14, 2009 at 5:04 PM
    Munky
    Munky Well-Known Member
    Beau
    Virginia Beach, VA
    4x4, Indigo, SR5
    Pace Edwards roll away, Chrome Steps, BFG All-Terrain T/A® KO 265/75/16
    which rims do you have? i have the TRD Offroad Rims on my SR5, i run 265/75/16 BFG ATs no rubbing they are 31.6"
    what r&p is in the 4cyl?
  12. Sep 14, 2009 at 5:10 PM
    MikeyD
    Sayreville NJ
    I have the 16" steelies painted black. But im going to get a new rim when i get tires because the paint is going to scratch off when i put new wheels on. So since im getting new rims i rather go with a 15 or 16" wheel.
  13. Sep 14, 2009 at 5:11 PM
    MikeyD
    Sayreville NJ
    And do you have any pictures? Post them please.
  14. Sep 14, 2009 at 5:19 PM
    Munky
    Beau
    Virginia Beach, VA
    4x4, Indigo, SR5
    gotcha, well if your getting new rims then go for it.
  15. Sep 14, 2009 at 5:23 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    why get new rims, steel wheels are stronger then alloy or alum, you can easily touch up paint on steel wheels
  16. Sep 14, 2009 at 5:25 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    by the way the suspension on the 4 & 6 cyl. are very different unless the TSB has been done
  17. Sep 14, 2009 at 5:27 PM
    MikeyD
    Sayreville NJ
    I was just going to get some steel rock crawlers. Ive been doing alot of searching and seen a few 2nd gen 4cyl with 33/12.5 tires with out regearing. So right now im tending towards the 32/11.5 km2s with a 15 inch rim. Do you guys think this is a good idea?
  18. Sep 14, 2009 at 5:29 PM
    MikeyD
    Sayreville NJ
    and by the way I like the way the bfgs look on your stock wheels.:)
  19. Sep 14, 2009 at 5:30 PM
    Munky
    Beau
    Virginia Beach, VA
    4x4, Indigo, SR5
    not sure how suspension came into this, what are the gears in the 4cyl ? 3.73 or 4.10 ... if it is 4.10 then you will be fine
  20. Sep 14, 2009 at 5:36 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    they are 4:10 and the suspension gives the 6 cyl a little more clearance between the fender flare and tires
