32" bfg ko2 psi?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hoosierchieftaco, Jul 6, 2016.
  1. Jul 6, 2016 at 1:03 AM
    hoosierchieftaco
    hoosierchieftaco [OP] Well-Known Member
    kevin
    indiana
    2016 SR DCSB
    front ome 888 5100s/// rear deaver aal toytec shocks///electical: morimoto hids switchback drls rci skid 285/75/17 firestones
    i am running 32" bfg ko2 they are e-load i am running 32 psi in them what is everyone else running is this not enough this was the recommend from dealer.
  2. Jul 6, 2016 at 1:20 AM
    BDMcGuire
    BDMcGuire Well-Known Member
    Brent
    Peoria, AZ
    06 Tacoma OR SBDC
    Out here in AZ on the street in the winter I run 45ish. In the summer I go between 35-40 depending on how hot it is.
    Edit: summer I inflate to 35-40 because the heat will expand making it go to 45
    hoosierchieftaco[OP] likes this.
  3. Jul 6, 2016 at 2:26 AM
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    i run mine at 35psi. anything 40^ seems to give it a really rough ride.
  4. Jul 6, 2016 at 3:29 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What size, exactly?
  5. Jul 6, 2016 at 3:40 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    PSI "required" will vary with rim width, truck weight, cargo weight, AND tire size. First, you need to establish a good contact patch....No arbitrary inflation number. If you had a 3/4-ton pickup that routinely hauled a couple thousand pounds in the bed, you might want 60 or 70 psi....(or more) A Tacoma that runs around empty most of the time, 30PSI might be enough.
    I'm running Duratracs....I've heard tire pressures mentioned from 28 to 60. After a little experimenting, I'm good @ 34psi. Wear is minimal, the entire width of the tire is in contact with the road, the ride is great, gas mileage is as good as a Tacoma will get, and it hauls an average load safely.
    Bottom line, these trucks don't need tires blown up to 50 or 60 psi. Tire manufacturers will have a max inflation number for maximum hauling capacity, but that's not a realistic number with a lightweight truck in normal driving conditions....
    Run the pressure too low, tires heat up and INCREASE psi. There's a sweet spot somewhere in the middle. (Usually in the 32 to 36 psi range) If driving causes pressure to raise more than 4 or 5 psi, you're starting off too soft....
  6. Jul 7, 2016 at 11:40 PM
    hoosierchieftaco
    kevin
    indiana
    2016 SR DCSB
    Thanks all for opinions I am pretty sure I am running 285 75 17s maybe 275 not sure without looking they were on truck when I bought it
  7. Jul 7, 2016 at 11:42 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Chalk test.
  8. Jul 7, 2016 at 11:44 PM
    hoosierchieftaco
    kevin
    indiana
    2016 SR DCSB
    I have done that for my race car I run scca but mostly to see how much camber I need to run etc... not so much on psi
  9. Jul 7, 2016 at 11:46 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Many people use chalk testing for psi. Google it or even YouTube it. Tire PSI varies from truck to truck, there's no right answer.
  10. Jul 8, 2016 at 1:08 AM
    BertMacklin
    BertMacklin Well-Known Member
    Colorado
    2016 MGM TRD OFFROAD M/T
    Archive Garage Shackle Flip, Bilstein 6112s Front, Fox 2.0 Extended rear shocks, AAL, SPC Racing UCAs.
  11. Jul 8, 2016 at 7:25 AM
    splitbolt
    NW Arkansas
