32" LED Light Bar Mounts - Stealth and Flush for 3rd Gens
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MojaveMadman, Dec 22, 2015.
  1. Feb 12, 2016 at 9:14 AM
    #161
    ridez
    ridez Well-Known Member
    vancouver bc
    2016 white DCLB TRD sport with upgrade package
    OME 887s, 5100s, deaver AAL, light racing UCAs
    I believe it's the light green wire on the cargo lamp. I spliced into that and my light works well. Turns on with the dash lights.
  2. Feb 12, 2016 at 9:31 AM
    #162
    Woody79
    Woody79 Well-Known Member
    Kevin
    Utah
    2016 DCSBOR 4x4 Quicksand
    Icon Stage 2 TRD Pro Wheels 285/70/17 BFG KO2's Header Rail Extang Solid Fold 2.0 Tonneau Cover
    Yes. Green wire on Cargo lamp. Only green wire there is. Peel back the tape a little bit and use a T-Tap to tap the wire.
  3. Feb 12, 2016 at 9:34 AM
    #163
    Woody79
    Kevin
    Utah
    The cargo lamp switch is the switch on the left hand side of the dash that turns on the bed light (cargo light). Unplug the wire harness from the back of that switch and tap the green wire as shown. This picture:
  4. Feb 12, 2016 at 2:52 PM
    #164
    Buddha717
    Buddha717 Well-Known Member
    Ron
    Harrisburg, PA
    2016 Inferno Tacoma TRD sport DCLB PTJBL
    I think I get it now. I wasn't understanding where or what the cargo light was located. It just hit me that the reference is the cargo light switch coming off of the dash. Correct?
  5. Feb 12, 2016 at 3:10 PM
    #165
    Woody79
    Kevin
    Utah
    Yep! Exactly
  6. Feb 12, 2016 at 4:41 PM
    #166
    jemail
    jemail Member
    Oahu, HI
    '16 DCSB 4x4 OR
    Thanks for the write-up. This really helps.
  7. Feb 15, 2016 at 9:21 AM
    #167
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    Can you specify where you cut and what did you keep?
    I'm having trouble understanding this part.
  8. Feb 15, 2016 at 9:50 AM
    #168
    MojaveMadman
    MojaveMadman [OP] Cali Raised LED
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    All mounts sold as of yesterday. Thank you very much TW Fam!!! I am still here if anyone needs anything at all.
  9. Feb 15, 2016 at 1:41 PM
    #169
    Buddha717
    Ron
    Harrisburg, PA
    Cut the harness before the white connector so that you can red just the wire through the firewall. There will be plenty of extra. once you push the wire through the firewall you can then see it if you removed the panel.
    Tacoma2GR[QUOTED] likes this.
  10. Feb 15, 2016 at 1:59 PM
    #170
    Woody79
    Kevin
    Utah
    Yep, correct!
    Everything is the picture is removed and not used, discard the entire assembly in the pic. You can see the cut wires in the pic just before the white connector.
  11. Feb 15, 2016 at 2:05 PM
    #171
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    Thank you guys for clearing this up for me.
    All three wires are going through the firewall correct?
  12. Feb 15, 2016 at 2:22 PM
    #172
    Woody79
    Kevin
    Utah
    Correct. All 3 go through the firewall and hook up to the back of the Mictuning switch. You'll have a 4th wire that goes from the Mictuning switch directly over to the Cargo Light switch (green wire).
  13. Feb 15, 2016 at 2:24 PM
    #173
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    where are you guys getting these switches from?
  14. Feb 15, 2016 at 2:33 PM
    #174
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    Too easy, thanks guys.
  15. Feb 15, 2016 at 2:33 PM
    #175
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
  16. Feb 17, 2016 at 4:08 PM
    #176
    CDPlaya
    CDPlaya Well-Known Member
    CD
    New Awlins Who Dat?
    Newbie
    None
    I received my order last week. Exceptional quality materials, down to the stainless hardware . The brackets are Bullet proof. :infantry:I could hang a tank from them lol. I took Chris' advice and used Rustoleum bed liner spray to paint them . The look sweet.
    Now all I need is a truck to mount them on. :mudding:
    Thanks Chris I appreciate everything
  17. Feb 17, 2016 at 5:39 PM
    #177
    ale214
    ale214 Well-Known Member
    Chatham, IL
    2016 OR 4x4 White
    I just got mine a little bit ago. Hope to install this weekend but I might wait for the BAMF grill. I saw the stuff about being overbuilt but I was way off in what I expected. I guess I was thinking of something sort of like what comes with most lights. These freaking things are heavy and solid. They are beautiful. I will buy from you any day.
  18. Feb 18, 2016 at 4:00 PM
    #178
    Aussiek2000
    2016 Offroad AC
    Where are you guys with access cabs wiring in for dash lights?
  19. Feb 19, 2016 at 3:50 AM
    #179
    th3118
    th3118 Well-Known Member
    Mesa, AZ
    2016 Quicksand TRD Offroad
    I used the trailer brake connector. It is tucked in under side panel. I think it was a green wire, but I don't remember for sure. Check it out with a meter.
  20. Feb 19, 2016 at 4:24 PM
    #180
    Krezz
    Krezz Well-Known Member
    Kevin
    Ontario, Canada
    '18 Tundra Platinum Crewmax
    All mod's listed on website - regarexpeditions.com
    Mounts arrived today... very pumped about them. Now to set aside some time to install and get my LEDs in behind the grill. Chris was awesome to deal with along the way and its sad that others will need to wait a while for his return to the mount world, but I'm sure all his products will reflect the quality in the brackets I've seen.
    Thanks again very much @MojaveMadman
    And because everything is better with pictures...
    LED bar install photos to follow... hopefully sooner than later.
    whopper and MojaveMadman[OP] like this.
