3200rpm cruising at 75?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SavageTRD17, Aug 11, 2017.
  1. Aug 11, 2017 at 6:12 PM
    SavageTRD17
    SavageTRD17 [OP] Well-Known Member
    2004 DC prerunner
    Hey guys, I've had my 17 off-road for about 8 months now. I just installed bilsteins 5100's with the rear Dakar heavy duty springs and 285/70/17 tires. I love everything about the truck except for the high rpms between 70-75. The tranny doesn't bother me when I'm driving around town or any speed up to about 65. However, the second I hit 70-75 on cruise this thing stays at 3200rpms unless I go downhill and then it finally shifts. I understand losing mpgs with the lift but I'm barely hitting 14mpg on the highway. I had the same set up on my 08 and still managed 18-19. Is this normal? And really the mpg doesn't bother me it's just the high rpms are starting to annoy the sh*t out of me. Are there any solutions or will I just have to get use to it? Almost wish I opted for the tundra if this was going to be the case.
  2. Aug 11, 2017 at 6:13 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Have you tried shifting up a gear?
    over60 and c4lvinnn like this.
  3. Aug 11, 2017 at 6:14 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Do you drive with the ECT Button on?
  4. Aug 11, 2017 at 6:29 PM
    SavageTRD17
    2004 DC prerunner
    I haven't tried shifting up yet. And that's my guess that for some reason its sticking in 4th. And right now I have the ect off but I've tried it while it's on and it's still the same.
    I've only had the lift on for a month now so I didn't know if the tranny will need to relearn my driving habits or not. I just wanted to see if anyone else was experiencing this.
  5. Aug 11, 2017 at 6:29 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Do you have a 2.7L with 4.88 gears.
    RIDERED67 and stevotivo12 like this.
  6. Aug 11, 2017 at 6:32 PM
    SavageTRD17
    2004 DC prerunner
    No I have the 3.5 off road package
  7. Aug 11, 2017 at 6:59 PM
    rjacobs
    rjacobs Well-Known Member
    has nothing to do with the lift and everything to do with the gears not matching the tire size anymore.
    Time to regear...
  8. Aug 11, 2017 at 7:07 PM
    desertjunkie760
    Shane
    Check My Sig.
    Bigger tires would drop your RPMs at highway speeds, not do what the OP is experiencing. Sounds like the truck isn't using all the gears in the trans.
    over60, BlakeM and tcjacado like this.
  9. Aug 11, 2017 at 7:49 PM
    rjacobs
    They cause the trans to NOT be able to up-shift because the RPM's would be to low to maintain speed. This is such a common issue with every vehicle that gets big tires put on it and not geared correctly. Not exclusive to Toyota's.
    Kilokato likes this.
  10. Aug 11, 2017 at 7:52 PM
    rjacobs
    When I go to 285's(or bigger) on my 17 I will be doing 4.88 gears(maybe 4.56, I havent researched a ton). I expect my RPM's to remain exactly the same as stock.
    I built a 14 Jeep Wrangler. Started with 32's and 3.73 gears from the factory. Roughly 19mpg average. I went to 37" tires on 4.5" lift and 4.88 gears(which was the correct gearing per the chart to keep my RPM's equivalent to stock) and guess what... my MPG was still around 19mpg and my cruising rpm was almost exactly the same as stock... Had I not done gears at the same time I would have expected the trans to never get to 5th on the highway and be stuck in 4th, hell might have never gotten to 4th, I dont know.
  11. Aug 11, 2017 at 7:57 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Since you're getting the same mpg as a Tundra, just get the Tundra and don't lift it, no need problem solved.
    At 78mph I'm just shy of 2000 rpm but that's without cc, no lift, stock size tires, and on flat land.
    The cc does seem to change how the truck shifts and behaves so I try to avoid it and wouldn't use it on hilly terrain.
    Yeah, it sucks I know, but I've maned up and its not killing me as most of my trips are under an hr drive.
    Hope that helps
    Cheers!
    hiPSI likes this.
  12. Aug 11, 2017 at 8:59 PM
    rdjr17
    rdjr17 Well-Known Member
    Ron
    Nepa
    2019 voodoo blue Trd pro
    The cruise control sucks on every toyota I've had , my dodge work truck cruise works a lot better you can set it to a specific speed plus it down shifts a lot smoother .
  13. Aug 11, 2017 at 9:13 PM
    treimche
    treimche Well-Known Member
    Fargo, ND
    This is "normal" operation according to Toyota. I have stock wheels and tires on my 2017 TRD Bro and the damn thing runs in 4th gear at 75mph almost all the time (unless there is a tail wind).
    The hammer likes this.
  14. Aug 11, 2017 at 9:37 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    There's the root of your problem, you're being haunted by your "wife" (2nd gen) because you left her for someone much younger. Your "wife" loved you and you betrayed her. You can stop all this madness if you trade this, this horrible monster back in. Your wife will still love you no matter what... And probably last another 200k miles before major service. :rofl:
    Gosh I love these threads :D
  15. Aug 11, 2017 at 9:48 PM
    2005 TRD Sport
    2005 TRD Sport Well-Known Member
    NM
    17 Black LTD
    Chrome step tubes, bed extender
    I figured out on mine, in cruise if you quickly pump and release the gas pedal, it will upshift.
  16. Aug 11, 2017 at 9:51 PM
    harrycary
    harrycary Well-Known Member
    Harry
    2016 Tacoma TRD Off Road
    Hi. Your truck does not have enough low end torque to upshift all the way with your tires, which are quite a bit larger than stock. You may want to regear with a 4.56:1 or 4.88:1.
    over60, The hammer and Kilokato like this.
  17. Aug 11, 2017 at 11:34 PM
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    Stop using cruise control and let the speeds fall a few MPH when you're going uphill and load increases.
    Learn to finesse the pedal so it will only downshift to 5th. Cruise control, in my opinion, is overly aggressive in some situations and shifts from 6th to 4th and won't upshift until the load has decreased for a period of time.
    I take a 140 mile trip quite often on a highway that has a 75 mph speed limit. With cruise on the entire way, I'll get about 17 mpg. If I finesse the pedal and let the speeds drift between 70-75 to avoid unnecessary downshifts, I can consistently get 18 - 18.5 mpg.
    over60 and jsinnard like this.
  18. Aug 12, 2017 at 4:28 AM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    2016 SR5 Access Cab V6 Auto 4wd
    Limited wheels, extra rope hooks in bed.
    This is exactly spot on...The engine doesn't have enough torque (or power) to run low rpms with the bigger tires so it has to stay in 4th-5th gear.
    Have you ever rode a multi-speed bicycle? Same theory. You can't ride around everywhere in 10th gear. You don't have enough power in your legs.
    Edit: "Can't"
  19. Aug 12, 2017 at 4:34 AM
    harrycary
    Harry
    Great example
    over60 likes this.
  20. Aug 12, 2017 at 4:38 AM
    harrycary
    Harry
    I do what you do, and it works well for me also. I think the OP's tires outgrew his gearing. OP may need to regear or shrink the tire diameter below 30 inches.
    over60 likes this.
