32's fit,but rims hit calipers :( zero offset the fix?
Discussion in '1st Gen. Tacomas (1995-2004)' started by whiteout, Nov 21, 2011.
  1. Nov 21, 2011 at 8:58 PM
    whiteout
    whiteout [OP] Active Member
    batonrouge,la
    TBA
    I scored some 15x8 rock crawler rims on 32 BFG's from craigslist.I put them on today and the rim hits the caliper,but seems to look like i can run a 32 on stock suspension.I called 4wheelonline and ordered the same set with a zero offset as he suggested.Hope he's right and it works.Here are a few pics.
  2. Nov 21, 2011 at 9:00 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Las Vegas, Nevada
    2003 Tacoma TRD 4X4
    Maybe I'm wrong, but those look wider than 15x8's? :confused:
  3. Nov 21, 2011 at 9:00 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total chaos Long travel kit, swayaway coilovers, deaver leaf pack with icon resi's
    you could just get some wheel spacers that would be easier
  4. Nov 21, 2011 at 9:12 PM
    CHPTR11
    CHPTR11 Team Impulse Red
    Dan
    Pacific NW
    2004 TRD Tacoma
    OME, Hankook, ARB, SCS
    Agreed, they look like 15x10's.
    People have had luck with shaving down the back of the wheels to clear the caliper. Or you can run some .25" wheel spacers.
    Regardless, those wheels and tires look way too big for your stock suspension set-up.
  5. Nov 21, 2011 at 9:14 PM
    kite
    kite Well-Known Member
    Squamish, BC
    Red Truck
    This is a BAD idea. If you're going to grind anything, grind the caliper.
  6. Nov 21, 2011 at 9:17 PM
    CHPTR11
    Dan
    Pacific NW
    2004 TRD Tacoma
    Hey just reiterating what I have read people doing, I recommend buying wheels with the correct BS.
    I know the 15" D-ring steel wheels have caused people problems with rubbing and have heard that the issue was resolved with grinding a small amount of the back side of the wheel.
    That being said, get a small lift and put some wheel spacers on. Check out VA-countryboy's truck, he's running the same wheels and tires.
    Edit: Here is his thread:http://www.tacomaworld.com/forum/1st-gen-builds/83232-1999-tacoma-build.html
  7. Nov 21, 2011 at 9:22 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Damn, do those have any backspacing? I wouldn't stack a wheel spacer on with those, your wheel bearings will hate you and your scrub radius will be terrible.
    Where are they rubbing on the wheel?
  8. Nov 21, 2011 at 9:26 PM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    I someone with the same wheels, they had to run a 1/4" wheel spacer.
  9. Nov 21, 2011 at 9:28 PM
    cummins6speed
    a 1/4" spacer wont make it much worse but make sure to get longer wheel studs
  10. Nov 21, 2011 at 9:29 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Yeah , and Possibly ET lug nuts
  11. Nov 21, 2011 at 9:38 PM
    whiteout
    batonrouge,la
    TBA
    Maybe i should measure them.....:confused:
  12. Nov 22, 2011 at 12:02 AM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    Prepare for a lot of rubbing.
  13. Nov 22, 2011 at 12:31 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    that's what my ex used to say... she was so damn hard to please... although i never had to worry about working out... she was plenty exercise...
    ok, back on topic...
    :cool:
  14. Nov 22, 2011 at 8:50 AM
    radcat692000
    radcat692000 Well-Known Member
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    a small washer about 1/8 or 1/4 of an inch thick around the lug nut holes should give you the clearance u need...i had to do this with my car rims.... should still have enough lengh left on your studs to get a good bite with your lug nuts
  15. Nov 22, 2011 at 9:31 AM
    cummins6speed
    That doesn't sound like a very good idea to me
  16. Nov 22, 2011 at 9:39 AM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    works the same as a spacer, except spacer is just 1 piece. your just simply trying to get clearance away from the caliper. its a simple fix bro...
  17. Nov 22, 2011 at 9:41 AM
    cummins6speed
    Yeah a spacer is a single precision machined piece. The tolerance on washers is a little larger
  18. Nov 22, 2011 at 9:46 AM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    granted,,, i'm just trying to help the guy out, with a quick fix, (maybe until his new stuff arrives).
  19. Nov 22, 2011 at 9:52 AM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    when i had to do mine i simply went to the hardeware store, got 1/4inch washers that fit snug around the stud ( i remember they were stainless metric washers). and bam up and running... .75 cents max.. no down time, no waiting on parts... if they fit around the stud firm, ( washers) theres no chance of them going anywhere.
  20. Nov 22, 2011 at 10:05 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    X2
    We understand what you did. Its still not a good idea. You have a good chance at ending up with a wheel vibration
