32s on stock ride height?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Callen82, Aug 18, 2017.
  1. Aug 18, 2017 at 7:20 PM
    Callen82
    Callen82 [OP] New Member
    Cameron
    2012 Black Toyota Tacoma
    Will I be able to fit 32s on stock ride height with minimal scrubbing? I have a 2012 Tacoma prerunner
  2. Aug 18, 2017 at 7:21 PM
    Callen82
    Cameron
    And if not what tire size would y'all recommend, metric sizes if you know .
  3. Aug 18, 2017 at 7:24 PM
    Dlbfla
    Dlbfla Well-Known Member
    Fla.
    07tacoma
    I have 255/75r 17 which is basically 32x10 on stock height 07 4x4
  4. Aug 18, 2017 at 7:26 PM
    Dlbfla
    Fla.
    07tacoma
    I think the prerunner actually sits a little higher in the front also. I don't scrub at all so I think you'll be fine.
  5. Aug 19, 2017 at 4:45 AM
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    It will be fine
  6. Aug 19, 2017 at 4:49 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    265/75/16 - 265/70/17 are the biggest you can go on stock suspension or without cutting. Even then, you might need to remove the mudflaps if you got em.
  7. Aug 19, 2017 at 5:12 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    265/75's are 32" tall and typically fit with stock rim back spacing. If they rub it's usually on the mud flap "bump" that protrudes into the wheel well. Easily modified to remove that bump.
