32's or 285's?
Discussion in 'Wheels & Tires' started by R.etheridge, Mar 27, 2010.
  1. Mar 27, 2010 at 4:46 PM
    R.etheridge
    R.etheridge [OP] Well-Known Member
    Middle GA
    03 Tacoma TRD 4x4
    I have an 03 double cab TRD 4x4 non prerunner and just put a 3in suspension lift on it. I have 16inch 09 TRD rims and wanted to know should I go with 32's or 285's? Or can I go bigger without having to modify any fenders? I will be putting yoko geolanders AT's on it. Wgat you guys think?
  2. Mar 27, 2010 at 4:46 PM
    DieselTech
    DieselTech Well-Known Member
    Jeremy
    Nova Scotia
    2005 Taco
    3" Lift, Eagle Alloys, 285/75 Mickey Thompson BAJA's, Flowmaster 40 series, 8000k HID's, Low-pro tool box, 7" touchscreen with JBL speakers and sub,
    285's FTW!
  3. Mar 27, 2010 at 4:48 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have 285's and they are just under 33"s. They are about 32.5"s to be honest.;)
  4. Mar 27, 2010 at 5:10 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Is this a trick question?
  5. Mar 27, 2010 at 5:11 PM
    TacoSupreem
    Hayden
    Kentucky
    if your question is whether or not to get 32's or 33's? Then i vote 32's!
  6. Mar 27, 2010 at 5:12 PM
    SURFTACO
    SURFTACO Well-Known Member
    New Jersey
    09 Tacoma
    3'' Pro Lift, 275 70 17 Tires Rear Suspension TSB Flat Black Stock Rims Seat Belt Chime off Fog Lights On anytime Jet pilot interior All weather floor Mats Tonneau Cover
    What type of spacers should ya use to prevent rubbing?
  7. Mar 27, 2010 at 5:15 PM
    TacoSupreem
    Hayden
    Kentucky
    If you are planning on running 285/70/17? Then you will want the 1.25" spidertrax hub centric wheel spacers!
  8. Mar 27, 2010 at 5:21 PM
    SURFTACO
    New Jersey
    09 Tacoma
    The spacer's expensive ?
  9. Mar 27, 2010 at 5:26 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    the 285 is the width isn't it? so your question doesn't even make sense:confused:
    the first number is width, second number is sidewall height (how tall your tire will be) the last number is the size of your wheel.
  10. Mar 27, 2010 at 5:26 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    I'd run 285's. Thats what I'm running right now and I like the look. The next set of tires I get will probably be 32's because of the loss of power with the four cylinder engine. But since you have the V6 i'd go 285's.
  11. Mar 27, 2010 at 5:29 PM
    bajaracer
    bajaracer Well-Known Member
    Charly
    Chandler
    06 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES,285/70/17 BFG'S AT KO'S MOTO METALS 17X8 3" REVTEK, SOUND SYSTEM
    I had '01 DC 32's on a 16x10 rim, front lifted an inch above leveled via Fabtech and had no rubbing except when offroading in exteme terrains,, I loved the way it looked and didnt seem to lose any hp
  12. Mar 27, 2010 at 5:44 PM
    SURFTACO
    New Jersey
    09 Tacoma
  13. Mar 28, 2010 at 4:44 AM
    R.etheridge
    Middle GA
    03 Tacoma TRD 4x4
    This was not ment to be a trick question. Im going to go with a 285-75-16 i believe unless I am going to dave to cut my fender flares. I just wanted to know what the biggest tire that I could fit under the truck with a 3 in lift without having to cut/modify my fenders or fender flares would be. They will be on 16in rims not 17's. My next question is will a 285-75 scrub on my upper control arm without a wheel spacer? I had a 3in on my 98 4x4 with 32/12.50's and when I turned sharp, it scrubed my control arm just a tad. I know the 285/75 is a 11.2 in wide so I should be good there right? I was ok with it but just wondering if I would have the same issue with the 285-75's
  14. Mar 28, 2010 at 5:22 AM
    tacoman101
    scott
    vermont
    With the 285's i'd buy some 1/4" wheel spacers from Wheelers.com, these will solve your UCA rubbing problems. Now the tires will still rub a little bit on the frame at full lock, but its really no big deal.
  15. Mar 28, 2010 at 11:40 AM
    Tacofanatic05'
    Tacofanatic05' #1 Member
    Hunter
    Waynesville/Charlotte,NC
    05' Tacoma 4x4 sr5, 3 Inch lift
    16'' American Racing wheels, 285/75/16 Cooper Discoverer St tires, Bilstein 5100 w/eibach coils, K&N Cold Air Intake, Flowmaster Super 44, 1 in 2 out exhaust. Tractor Supply Tool Box, No Mud Flaps, Mossy Oak Seat Covers, Oakley Decals, Hoyt Decal, Window tint 20% on sides 5% on top front windshield, Uniden Cb, and Window Deflectors.
    I think they are $50 a piece
  16. Mar 28, 2010 at 1:58 PM
    nitrojones
    nitrojones Member
    Joe
    Nola
    OME 3" kit, TC UCA's
    OK, check my math, but I've got the same concern, and I just went and took some measurements.
    I have stock 16x7 rims (which have 5.25" back spacing).
    I'm only clearing the UCA by about 0.5" right now, which means:
    There's 5.75" between the planes created by the UCA and the hub face.
    My new ride is going to be 16x8 rims w 4.5" back spacing. So I'm adding 0.75" to the distance, minus the 0.5" growth in rim size, which means I'm netting 0.25" clearance. I think the UCA is a non-issue. Spacers may help in fender and skid plate clearances, but it's on hold for me.
    How is it possible that there are that many people out there who don't know how to read tire size??
    285 HAS NOTHING TO DO WITH HEIGHT!
  17. Mar 28, 2010 at 2:57 PM
    tacoman101
    scott
    vermont
    The Spidertrax spacers are $100 a piece, i wish they were $50:rolleyes:
  18. Mar 29, 2010 at 1:20 AM
    R.etheridge
    Middle GA
    03 Tacoma TRD 4x4
    yeah my bad on that, I was in a hurry and wasnt thinkin. plus, I got drunk the night before! lol I know that 285 is your width its 285mm and 75 is the sidwall heigth. Thats a lot for spacers! im going to go without, I did with the 32's on the 98 and it wasnt a huge problem for me. Im going to go with terra grapplers or geolanders for tires. What do you guys think?
  19. Mar 29, 2010 at 2:57 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Actually there $100 buck a set ( 2 )...not each
    :cool:
  20. Mar 29, 2010 at 6:27 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    x2
    x2
