32x11.5x15 bfg at's on 15x7 any good?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoma matt, Feb 19, 2010.
  1. Feb 19, 2010 at 1:46 PM
    tacoma matt
    tacoma matt [OP] Member
    South Jersey
    95 Standard cab 4x4, Ultimate lift kit
    k&n, deckplate, throttle body spacer, Toytec ult. lift kit, cust. bumpers front and rear, cust exaust.
    Hello i have a 99 standard cab 4x4 i4. This is my first lift/tire upgrade and any input would be appreciated. I am in the process of installing the 3'' toytec 'ultimate lift.' I also purchased bfg at ko's size32x11.5x15. I was told these would fit with the lift and the stock wheels (15x7). Does anyone see any problems here or have any input. Thanks Matt
  2. Feb 19, 2010 at 1:47 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    yea nothing wrong with that, your tire is gona bulge out a bit but that's fine.
  3. Feb 19, 2010 at 1:50 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    that will work fine
  4. Feb 19, 2010 at 1:51 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    Not too sure about 1st gen, but I run 285/70/17 with some spidertraxx spacers and have the ready lift SST kit so I say you should be fine IMO and from what I've seen on here. Make sure to post some pics
  5. Feb 19, 2010 at 1:52 PM
    tacoma matt
    South Jersey
    Thanks for the quick reply. Will everything fit properly with no rubbing or will i have unusual tread wear bc of the 15x7
  6. Feb 19, 2010 at 1:54 PM
    tacoma matt
    South Jersey
    Thanks for the quick reply. Will everything fit properly with no rubbing or will i have unusual tread wear bc of the 15x7. Will B sure to post pics when completed, new to site sorry bout no pics yet
    sorry im new to the whole thread posting thing, never done this before just looking for some info
  7. Feb 19, 2010 at 1:55 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    Should fit fine, it might rub on the frame a bit at full lock, but if that's the case you can get a small wheel spacer to fix the problem, or new wheels!
  8. Feb 19, 2010 at 1:58 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    Im pretty sure you will be fine I put that same tire but the km's on my 2000 tacoma with a 3' lift and had zero rubbing
  9. Feb 19, 2010 at 1:59 PM
    tacoma matt
    South Jersey
    i was considering 15x8 wheels. but with the backspacing and offset everything just got confusing. if i did go with a 15x8 do you know what i would need?
  10. Feb 19, 2010 at 2:03 PM
    tacoma matt
    South Jersey
    if i was to go up to a 15x8 wheel do you know the backspacing or offset i would need for my 99. and very nice truck i like the cap and the black wheels
