32x11.5x15 on a 7'' rim ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoma matt, Mar 1, 2010.
  1. Mar 1, 2010 at 2:46 PM
    tacoma matt
    tacoma matt [OP] Member
    South Jersey
    95 Standard cab 4x4, Ultimate lift kit
    k&n, deckplate, throttle body spacer, Toytec ult. lift kit, cust. bumpers front and rear, cust exaust.
    I just installed a 3'' coilover lift on my 99 i am going to run 32x11.5.15. i was told they should be mounted on a 15x8,9,or10'' rim. I know that it can be mounted on my stock 15x7. This being my daily driver i was wondering if there were any major problems doing this. Thanks for the help
  2. Mar 1, 2010 at 8:09 PM
    S-M-R-T
    S-M-R-T Well-Known Member
    I run 12.5" tires on an 8" rim just fine. I believe that there is a rule that says that the tire shouldn't be more the 4" wider then the rim. That being said a tire on a 7" rim will cause the tire to 'balloon' more making the sidewalls slightly more vulnerable offroad. You will have to run a bit less pressure to keep the contact patch flat which will theoretically affect mileage a tad. There is also more movement in the sidewall so it will not handle quite as precise as putting it on a wider rim.
    Basically I would say that if you like the rims you have it won't hurt to use them. On-road a wider rim will handle better and the tire will last slightly longer but there is not even close to enough difference to justify the cost of new rims if that is the only reason.
  3. Mar 2, 2010 at 2:25 PM
    SixtyDashOne
    SixtyDashOne Well-Known Member
    Collegeville, PA
    2021 ArmyGreen TRD Sport, 2007 Regular Cab 4x4
    Correct. General rule of thumb is to keep it as CLOSE to 2" on each side as possible (4" total)
