32x11.5x17 or 285/65/17 ...yes I searched!
Discussion in 'Wheels & Tires' started by zjolsen, Oct 1, 2009.
  1. Oct 1, 2009 at 8:15 AM
    zjolsen
    zjolsen [OP] Go Huskers!
    Zach
    Omaha,NE
    2010 Double Cab TRD SPORT 4x4
    Pro dry S, Secondary filter removed, LaminX yellow fog light covers, Westin Step Bars
    I could not find any threads or good links to find a good A/T tire in either of these sizes. I dont want to go to a 33" tall tire because of speedo being off and any less fuel economy, along with trimming. The 32x11.5 I do not think would require any trimming and give me the look I want and still be very close to stock height (A tad over 1" taller and 1" wider).
    So... Can anyone help me find some decent priced tires in these sizes? It needs to be a long lasting tire as I doubt I will really wheel with this tire besides in the fields every once in a while.. For wheels.. I will be purchasing Pro Comp Xtreme 7005 Series in black 17x8 with 4.5 BS.. so I should not need any type of spacer either... just need to keep the mudflaps off.
    I just purchased a OME Suspension kit from toytec and would like to put it on all at once..
    Can anyone help?!
    Thanks,
    Zach
  2. Oct 1, 2009 at 8:19 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
    On the speedometer issue...
    I have a stock 09 TRD Sport with 17"s. The speedo is off by about 4 mph - according to the more accurate Garmin. If the Garmin says I'm going 60mph, the truck is reading 56mph.
    How much would 33's (or 32.5's) affect your speedometer? It may even it out!
  3. Oct 1, 2009 at 8:27 AM
    zjolsen
    Zach
    Omaha,NE
    Another thought was going with a 275/70/17.. which equates to 32.16x10.83 ..not as wide as I would like..but it would ket me in the size range I want. Thoughts?
  4. Oct 1, 2009 at 4:09 PM
    zjolsen
    Zach
    Omaha,NE
    bumpity.. bought 7089s in 17x8 w/ 4.5bs.. hopefully have them by next week so I need to find some dang tires!
  5. Oct 1, 2009 at 9:24 PM
    GASH
    GASH Well-Known Member
    Josh
    Albuqueruqe
    07 TRD 4x4 DC
    Fox 2.5" Remote Reservoir Coil-Overs, All Pro Expedition leafs with Fox adjustable shocks, Armor Tech Offroad Skids, NST Lite Weight Pulleys, WeatherTec Floor Liners, TRD CAI, Custom Decals, Wheelers Super Bumpstop
    your probably having trouble finding results because those tire sizes are not very common. I did a quick search on tire rack and the only 285/65/17 that came up was a yokohama geolander. Nothing came up for 32x11.5x17 from what i've seen usually 15" tires come in that format.
    A 265/70/17 will fit without rubbing anything bigger and you'll need to trim. FWIW when I went to 265/70 from 265/65 it corrected my speedo.
