33’s on a ‘21 4-cylinder??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma-727, Jun 27, 2021.
  1. Jun 27, 2021 at 9:11 AM
    Tacoma-727
    Tacoma-727 [OP] Member
    2021 Tacoma SR 2.7L
    Hello All!
    New member here and overall new Tacoma owner (my first one) and I was curious about running 33’s on a 2021 Tacoma 4cyl. I was thinking something with a 17” wheel as well…Not sure if it would be too much stress on the engine with the bigger tires/wheels? Also, I drive quite a bit for work so maybe Toyo Open Country A/T 3’s? I understand a leveling kit or small lift kit (2-3”) would be necessary to prevent rubbing and give clearance?
    Any and all feedback would be greatly appreciated!! Thanks in advance!!
  2. Jun 27, 2021 at 9:17 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    First question - WHY?
    The 4 cylinder is notoriously doggy as it is. Bigger tires will require regearing to get you back to the mediocre zip you have with the OEMs.
    Save your $$$ for more cosmetic stuff.
    Chew and Tacoma-727[OP] like this.
  3. Jun 27, 2021 at 9:18 AM
    You Suck I Suck More
    You Suck I Suck More Well-Known Member
    Meatloaf
    North Florida
    2017 Super White DCSB TRD OR
    Your parents' favorite Airman
    It won't be fun but you can do it. Just hope you don't need to get anywhere in a hurry
    Tacoma-727[OP] likes this.
  4. Jun 27, 2021 at 9:31 AM
    Tacoma-727
    2021 Tacoma SR 2.7L
    Ah understood! Well without compromising any torque what is the largest tires you would recommend putting on it?
  5. Jun 27, 2021 at 9:31 AM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    If you’re committed to 33’s, definitely go the skinny route; 255/80/17 or 255/85/16. The lighter the better.
  6. Jun 27, 2021 at 9:34 AM
    Bishop84
    Bishop84 Well-Known Member
    265/75R16 is the most reliable tire size, its slightly bigger than stock (wider and taller) and gives the aggressive look you want.
    661, Junkhead, RyanL and 2 others like this.
  7. Jun 27, 2021 at 10:06 AM
    angerbot
    angerbot Well-Known Member
    The problem with skinnies is that they're all load range E and mostly mud terrains or very aggressive. There are several 285/70R17s that come in lighter than any 33" skinny that I've seen:
    - Toyo OC RT at 49lbs
    - Duratracs at 50lbs
    - Falken Wildpeaks at 50.5lbs
    RushT[QUOTED] likes this.
  8. Jun 27, 2021 at 10:09 AM
    Slappymane
    Slappymane Member
    Kaveh
    SF CA
    2017 Manual 4banger
    stock gang
    I would recommend 235/85 r 16s. I run the falken wildpeak all terrains and they measure 32" on my 4banger. Taken me a lot of places. Love em
    Kevagr23, Tacoma-727[OP] and RushT like this.
  9. Jun 27, 2021 at 10:11 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Anything taller than what you have will compromise torque. Keeping them light as possible will help minimize the pain.
    Chew likes this.
  10. Jun 27, 2021 at 10:11 AM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    The problem with the 285's is rubbing the cab mount/fender wells. The 255's for sure are coming in 10lbs heavier but you don't have to worry about rubbing at all and get the same height advantages
    Lt. Dangle likes this.
  11. Jun 27, 2021 at 10:13 AM
    angerbot
    Depends whether you're going for fuel economy or less work to fit I guess. Although someone pointed out the real correct answer for a 4cyl above and it's 265/75R16.
  12. Jun 27, 2021 at 10:14 AM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    Yeah I'm definitely in the less work to fit club. And I agree, the 265/75 are the right tire to get a little bigger and have no issues at all.
  13. Jun 27, 2021 at 11:48 AM
    RushT
    North Texas
    Yeah, I struggled with that too because I wanted a moderately aggressive look. Went with Toyo AT3 265/75/16.
  14. Jun 27, 2021 at 12:19 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    Junkhead likes this.
  15. Jun 27, 2021 at 12:27 PM
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    You can get a Yokohama Geolander A/T G015 in 255/75/17, 32" tire, and it weighs in at 41lbs. the 70/17 comes in at 37lbs and is a 31" tire.
  16. Jun 27, 2021 at 12:42 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  17. Jun 27, 2021 at 2:08 PM
    Tacoma-727
    2021 Tacoma SR 2.7L
    Thanks for the feedback guys, going to be going with 265/75/r16!
    RushT and Junkhead like this.
  18. Jun 27, 2021 at 2:09 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Do you only drive downhill?
    Skydvrr likes this.
  19. Jun 27, 2021 at 2:10 PM
    Tacoma-727
    2021 Tacoma SR 2.7L
    Yea both ways to work…
    Junkhead and skeletron like this.
  20. Jun 27, 2021 at 3:21 PM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    Cool. Well as long as it is straight roads 33’s will be dope.
