33’s on stock suspension it can be done!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Vst, Jan 17, 2021.
  1. Mar 10, 2021 at 12:10 PM
    #41
    evotacoma
    evotacoma Well-Known Member
    Great info and video! Thinking about putting 255/80/17 on 4R TRD PRO Wheels on a stock OR. Giving me confidence that it will work.
    Vst[OP] likes this.
  2. Mar 10, 2021 at 1:50 PM
    #42
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I would do 33/ 10.50s but they are too darn heavy, now if I could get them in a C or SL rating. I wonder if the 35/ 11.50s would work? I'm leaning towards the 285/70/17 SL Toyo AT3s. Very light and should not have any issues with on my 4runner sema wheels.
    VR812 and evotacoma like this.
  3. Mar 10, 2021 at 3:19 PM
    #43
    Vst
    Vst [OP] IG:@vehiclesupportedtravel
    Scott
    Kodak, TN
    18’ Access cab TRD OFRD 4x4
    To be honest I haven’t felt to much power loss from them. I’ll get my matching spare down and weigh the tire and wheel combo and see what it comes in at.
  4. Mar 10, 2021 at 3:21 PM
    #44
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    and no mud flaps. CANCELLED
  5. Mar 10, 2021 at 3:21 PM
    #45
    VaToy
    Parts Unknown
    Those tires are like 60 pounds, I think.
  6. Mar 10, 2021 at 3:31 PM
    #46
    Haun0002
    Haun0002 Well-Known Member
    2020 TRD sport 6MT - MGM
    How are these tires on wet/snow?
  7. Mar 10, 2021 at 3:32 PM
    #47
    Wulf
    Wulf no brain just damage
    rock raisin
    35s on stock suspension can be done if you up your cutting/welding tolerance
  8. Mar 11, 2021 at 7:45 AM
    #48
    Vst
    Scott
    Kodak, TN
    Haven’t really had them in snow but so far so good in the rain
  9. Mar 23, 2021 at 7:56 PM
    #49
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    To add onto the Kenda Rts:
    I've been running them for around 4k miles. They are a great tire, and thats coming from me running probably 20 different tires in my past. They are fairly quiet on road, handle well on the wet, and do amazing in the snow. I haven't noticed any wear really, just some rock rash. I've plowed up to the headlights in snow, not sure if its from the tires or the driver. So far they done well on the pnw trails, and I'm going to Moab next month so I'll get to see how they do on the rocks. They measure pretty true to size, under weight/35psi I have 32.8" and 10.5" wide on my 17x8.5 wheels. They are pretty heavy, just the tires are 60lbs each. The stock wheel/265 tires together were exactly 60lbs on my scale. I didn't really notice much power difference, it will still chirp the tires on a hard downshift and truck still pulls good. Only thing was the tranny freaking out on the highway, but an Ov tune has pretty much solved that. I can pull ~19mpg on the highway if I want, and 17ish city if I drive nice, doubted I dont have much weight on my truck yet.
    Vst[OP] likes this.
  10. Mar 26, 2021 at 8:50 AM
    #50
    Vst
    Scott
    Kodak, TN
    I agree love mine are you running a lift?
  11. Mar 26, 2021 at 12:22 PM
    #51
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    Like 1.75" in the front and .75" in the rear
  12. Mar 28, 2022 at 7:20 PM
    #52
    joecarey918
    joecarey918 New Member
    2017 MGM Tacoma TRD Sport
    What offset are you running? I have minimal rub with my 265/70r17 with a 2in lift but i run -12mm 17x9. Would definitely be interested in this size. Would like to keep my wheel setup but I'm guessing I screwed up to have any rubbing at the 265 albeit minimal rub
  13. Mar 28, 2022 at 8:20 PM
    #53
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    That was a long time ago/couple setups ago, but those wheels were +18mm.
