33’s on trd first gen?
Discussion in '1st Gen. Tacomas (1995-2004)' started by nave_knarf, Jun 13, 2023.
  1. Jun 13, 2023 at 9:37 PM
    nave_knarf
    nave_knarf [OP] Member
    Evan
    2002 Tacoma PreExtCab TRD
    Howdy folks, I got my truck not to long ago and it is bone stock except for the added trd spec, I would appreciate any feedback on if and how to fit 33’s, do I need to lift it first? By how much? Is regear necessary? Found a steal of a deal on marketplace but don’t want to pull the trigger till I know!
  2. Jun 13, 2023 at 9:59 PM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    It depends. Tell us more about your plans...
    What size 33's? 285? All terrain or mud terrain?
    Do you plan to keep your stock wheels? Some people rub at the UCA with 285 and some people don't. This will change if you get aftermarket wheels with negative offset (wheels stick out more)
    When you lift the truck and have negative offset you actually create more rub issues at the fender / pinch weld. Look up pinch weld mod as you'll likely need to do that.
    Are you auto/manual? Regear isn't necessary with manual. I have 4.56 with manual and RPMs are 3k+ at highway speeds. Not absolutely necessary on auto either but you'll notice a dip in low end torque.
  3. Jun 13, 2023 at 10:20 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Welcome to TW.
    If you are an auto, a regear will be a must. 33s will likey require a combination of some lift and some clearancing. How much of each will depend on how clapped out your old suspension is. How many miles on on that rig?
    You know, there are a ton of threads on this site that cover all of these topics. You should read some of them.
  4. Jun 13, 2023 at 11:42 PM
    nave_knarf
    Evan
    The tires I’d be putting on are 255/85/16 and there on some TRD beadlock wheels, and yes I have much more to look through but what I could find was people putting 33’s on somewhat modified tacomas, as the first upgrade I want to do I just wanted to see if it could be done as the first thing! Also my car is automatic at the moment and daily it to school and work. The tires are also BF Goodrich mud terrain tires. And thank you guys for the diligent responses, glad to be part of a great community!
  5. Jun 14, 2023 at 6:29 AM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    I did 255/70/17's (32" pizza cutters) on FJ Steelies with no lift and it BARELY fit. You'll want a lift for anything bigger. I always recommend Bilstein 5100's on a budget, or Old Man Emu's for a slightly larger budget. Call my buddy Hugo at https://runnin4tacos.com/ and he will have all of the information you will want/need.
    Ozark_RegCab likes this.
  6. Jun 14, 2023 at 6:34 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  7. Jun 14, 2023 at 6:56 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    These trucks really weren’t designed for big tires. Back in the 90s, 31s were considered to be a large tire size, and that’s about the largest they accounted for. I have 255/75/17s and even those rub slightly on the frame at full lock.
  8. Jun 14, 2023 at 2:10 PM
    boshak
    AG
    CA
    Perfect timing. This thread on that tire size popped back up recently: https://www.tacomaworld.com/threads/1st-gen-pizza-cutter-stance-255-85r16.540351/
    As Digiratus mentioned, a combo of lift & clearancing will be necessary. On auto and this size 33, I'd consider a regear eventually if not now. Trying to think as a student possibly on a budget, you don't necessarily have to do it immediately but will feel the bog. Although the diameter is taller than a 285, you'll make up on some drag efficiency because it's a narrower tire.
    I'm running the BFG M/T 255/85r16 on Procomp 8" wide wheels (-12 offset, 4 backspacing). I initially rubbed the frame slightly at full lock but stopped as the tire wore down. I did a pretty aggressive pinch weld mod so only rubbed the pinch weld at compression off road. Also important to note, I have about 2" lift with a uniball UCA that allows some forward caster adjustment to push it further away from the pinch weld.
    Also if you want to geek out on 255/85r16, this white paper is what pushed me in the 255 direction: https://www.purefjcruiser.com/docs/Skinny-tire-White-paper.pdf
  9. Jun 14, 2023 at 9:44 PM
    nave_knarf
    Evan
    Thank you so much for the info everyone and all the points in the right direction with all the advice I needed! I’ll be sure to check out those links and will reach out if I have any more questions but you guys have me just about everything I need!
