33” tire question, yes another one.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Skinny P, Dec 3, 2018.
  1. Dec 3, 2018 at 1:58 PM
    Skinny P
    Skinny P [OP] Well-Known Member
    Steven
    So on a stock 3rd gen Tacoma where exactly would the tire rub?
    On a Tacoma with a 3” lift where would the tire rub?
    Can I effectively delete my front bumper and add an off-road bumper in order to achieve 285’s on zero lift? 3” lift?
    Did a search... nothing in reference to adding a different bumper came up.. sorry if I missed it :deadhorse:
  2. Dec 3, 2018 at 2:05 PM
    siznarf
    siznarf Everyone my age is older than me...
    Francis
    Kommiefornia
    08 Taco
    91 Octane
    Assuming you mean 285/70/17 or 285/75/16:
    Cab mount and surrounding plastic
    Still cab mount ... unless you go crazy caster with aftermarket UCA ...no guarantees lol
    Maybe inner fender plastic and pinch weld cover.
    Rob Daman likes this.
  3. Dec 3, 2018 at 2:09 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    This is all
  4. Dec 3, 2018 at 3:12 PM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    There is no correlation between lift and increased tire clearance.
    If tire X rubs stock, it will still rub the same with a "lift"...all be it less often (maybe). Your tire will still compress upward and rub against what ever it was hitting before. Maybe not at ride height anymore, but if you hit a bump, bottom out or flex that tire is still able to make contact with what ever it was rubbing against before. Unless you install longer bump stops, restricting up travel, it will still rub.
    Anyways if I was you I would, remove fenders, hood and grill...Sawzall the entire inner fender/ core support off. Replace with full tube engine cage and one piece fiberglass front clip. Pay someone to build 4" over long-travel A arms, ditch that sad stock spindle and hubs and get a custom spindle/hub assembly. Lastly replace the pitiful stock rack steering with a real one and slap some 1" heim joints on the rods ends. Now you can run 37" tires all day.
    Professional Asian likes this.
  5. Dec 3, 2018 at 3:16 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    What about at night?
    Professional Asian and Gator352 like this.
  6. Dec 3, 2018 at 3:19 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    no, this is a day time activity only
