33/12.5/17's on a 3 inch lift HELP!!!
Discussion in 'Wheels & Tires' started by Eesh, Aug 8, 2009.
  1. Aug 8, 2009 at 9:29 PM
    Eesh
    Eesh [OP] Well-Known Member
    Canada
    2025 Tacoma Limited
    Hey guys I'm looking at getting a 3 inch lift (Icon front coilovers, Icon UCA, Icon Rear Resivoirs, and a Dakar Leaf pack. Thats going to cost some $$$$. So I really will only have enough money to get the Rubber and I'll keep my stock Rims for a while. I want to put 33/12.5/17's on. I know I'll have to do Trimming. But Should this in Theory work? Will I need any other parts?? Please Help with your info I have an 06 TRD Sport Double Cab long box. Cheers.!
  2. Aug 8, 2009 at 9:30 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    spacers mabey
    other than that i think your good
  3. Aug 8, 2009 at 9:35 PM
    Eesh
    Canada
    2025 Tacoma Limited
    What do you mean by spacers?? And where do they go? Do you have a link to any?
  4. Aug 8, 2009 at 9:39 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Wheel spacers go on the hub, between the wheel and the rotors.
    Here are some Spidertrax spacers, a recommended name for spacers.
  5. Aug 8, 2009 at 9:43 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    what he said
  6. Aug 8, 2009 at 10:22 PM
    fghtngsquirrel
    fghtngsquirrel Ka-freakin'-BOOM!
    Jacksonville, FL
    '08 4x2 Rad Red *SOLD*
    I just went through the same situation. If you're wanting to run the 285/70/17's, you will most definitely need the Spidertrax so the tires do not rub on the UCA's. If you go with spacers other than Spidertrax, make sure they are hub centric. Good luck!
  7. Aug 8, 2009 at 10:29 PM
    Incognito
    VA
    Hub centric is the trick here . . .
  8. Aug 8, 2009 at 11:15 PM
    Eesh
    Canada
    2025 Tacoma Limited
    So do these Wheel Spacers work really good? or are there alot of problems with them??? Pros and cons??
  9. Aug 8, 2009 at 11:20 PM
    fghtngsquirrel
    Jacksonville, FL
    If you are unable to replace your factory rims, then the Spidertrax are the best way to go, as they are specifically made for our trucks. Most other machined spacers/adapters are lug centric, which can cause bad vibrations. The Spidertrax are also coated so they are resistant to corrosion.
    Since these bolt on to your factory studs and then provide new studs for the rim, you always run the risk of them breaking, though I have only heard excellent things about Spidertrax (and a lot of people on TW use them). Hope this helps some!
  10. Aug 8, 2009 at 11:34 PM
    Eesh
    Canada
    2025 Tacoma Limited
    Do all 4 wheels need the spidertrax? Wheres the best place to buy them? Does anyone know of anyone who's running 33's on a 3 inch lift? That I could talk too. It would really help. Or are 33's just too big and I have no choice but to go with the 285's. If I did go with the 285's would I still need the spidertrax??
  11. Aug 8, 2009 at 11:40 PM
    fghtngsquirrel
    Jacksonville, FL
    285/70/17 are 33"s, and I am currently running this size with a 3" suspension lift and stock UCAs (for the time being). The Spidertrax will push the wheel/tire out 1.25", so they are needed for the front, but most people do all 4 so it's uniform. You can buy them at spidertrax.com. If you want, feel free to PM me!
  12. Aug 9, 2009 at 4:12 PM
    rpparkster
    rpparkster Well-Known Member
    Roger
    Long Beach, CA
    2009 Tacoma TRD 4X4
    TRD FJ Wheels, 285 GY DuraTrac's, Fox 2.5 C/O w/ Res, TC UCA's, Demello Sliders,AllPro 3" Leaf Pack, Walker Evans 2.0 Adj. RR, AllPro Front Bumper & IFS Skid, Timbren Bump Stops, Leather
    I don't think you can put a 12.5" width tire on stock wheels. They're too wide and probably not the safest thing.
