33/12.50/17 tires rubbing?
Discussion in 'Wheels & Tires' started by tarheeler, May 14, 2014.
  1. May 14, 2014 at 10:57 AM
    tarheeler
    tarheeler [OP] Well-Known Member
    Newport News, Va
    06 PreRunner TRD offroad
    3" lift
    I have a 2006 AC cab with Nitto mud grapplers, 3" lift. They rub on 3/4 turn or more. Looking to get different tires, don't want to go too much smaller. The 285/70 shows it to be 32.7/11.22. Shouldn't this work if I get an AT tire. Wondering if its the side biters that are rubbing
  2. May 22, 2014 at 1:16 PM
    tahoe_babbs
    tahoe_babbs Well-Known Member
    Sacramento CA (Folsom)
    08 trd taco
    As needed, and some not.
    Look into cab mount chop
  3. May 22, 2014 at 1:19 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    This.
    And, what's your wheel backspacing?
  4. May 22, 2014 at 1:19 PM
    nucktaco
    nucktaco Well-Known Member
    Scott
    south surrey, bc
    08 Double Cab TRD Sport
    satoshi mod, sliders, tinted tails/3rd brake, 3" lift,
    you running a spacer? ive got a 285/70R17's in the BFG KM2 and never had an issue with rubbing badly. had to remove my mudflaps and trim a bit of the flare but havent done the cab mount chop. ive got 1inch or 1.25 inch spacers in the front. cant remember 100%.
  5. May 22, 2014 at 1:54 PM
    tarheeler
    Newport News, Va
    3" lift
    I just bought it and don't know if it has spacer or not, can't get the guy I bought from to answer phone
  6. May 22, 2014 at 2:04 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    It probably isn't the diameter of the tire as the width. The 33-12.5 is usually close to an inch wider than a 285-70 causing a full size 33 to rub more. This definitely depends a lot on the backspacing of the wheel and if spacers are being used as well. so by going to a 285 from a 33 might solve your problem without sacrificing overall diameter that much.
  7. May 22, 2014 at 2:20 PM
    tarheeler
    Newport News, Va
    3" lift
    I'm guessing 4.5" backspace, they are 17" Helo wheels and they come with 4.5 or 5.5 backspace.. I'm thinking going to the 285/70 might solve the problem. Most likely gonna get some Toyo AT which aren't as aggressive and put these up for sale. Thanks for the help guys
  8. May 22, 2014 at 9:08 PM
    AviatorRuss
    AviatorRuss Member
    Russ
    Tacoma, WA
    2014 DCLB TRD Sport 4x4 Red
    No mods yet...
    Thread HIJACK....
    JRobson,
    How do you like those Mickey T's? I've been looking at the Baja ATZs myself. I don't see a lot of Taco's with'm...not sure why. How are they wearing..noise etc? Thanks!
