33 inch tires on Stock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 123toycoma, Oct 9, 2019.
  1. Oct 9, 2019 at 9:52 AM
    123toycoma
    123toycoma [OP] New Member
    Adam
    Base Tacoma
    I have a 2011 stock tacoma with 16 inch wheels and want to put 33 inch tires on am I going to need a lift or level kit? I can't get a straight answer from anywhere??
  2. Oct 9, 2019 at 10:01 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I’ll don’t believe so. But here’s an easy idea. Run down to the tire shop and have them mount a 33 on your rim and put on your truck, you’ll have your answer pretty quick.
  3. Oct 9, 2019 at 10:04 AM
    15TACOSPORT4X4
    15TACOSPORT4X4 Well-Known Member
    Stan
    2015 Black Tacoma TRD Sport 4x4
    3" lift on 33 inch Nitto's with 18" Fuel wheels. N-Fab step bars. Husky floor liners.
    Sure it will fit. As long as you drive straight.
    DriverSound likes this.
  4. Oct 9, 2019 at 10:06 AM
    Brofessor
    Brofessor Well-Known Member
    You can. As long as you don’t mind cutting, bending and trimming, lifting, realigning.
  5. Oct 9, 2019 at 10:06 AM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    It all depends on if you want to turn or how much your willing cut
  6. Oct 9, 2019 at 10:09 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Your gonna need a lift, cmc, proper sized wheels ie offset and backspacing, if you’re gonna keep stock rims plan on some hub centric spacers.
    You can fit a 255/85/16 or 255/80/17 and be stock may have to trim some of the fender liner up front and remove mud flappers.
    mauigrown and El Duderino like this.
  7. Oct 9, 2019 at 10:11 AM
    bzzr2
    bzzr2 Well-Known Member
    255/85r16 will fit using stock wheels. basically 33x10 = pizza cutters. as above, maybe remove mud flaps up front, maybe not. not all 255's are created equal. the Toyo MT is 33.5 tall, the Cooper ST Maxx is 32.8 tall etc....
    MattCowsmasher likes this.
  8. Oct 9, 2019 at 10:17 AM
    mauigrown
    mauigrown Well-Known Member
    2011 4x4 DCSB TRD sport
    Straight answer is yes, you can with alot of cutting. Realistically for most people no.
  9. Oct 9, 2019 at 10:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    Something to think about.
    Do you need 33", or want them?
    ie, is this a functional issue or cool factor?
    If functional, dive in and take required corrective actions as problems arise. Not cheap, but a requirement to fulfill a function.
    If cosmetic only, you can certainly proceed, just realize there is a price to be paid for the look.
  10. Oct 9, 2019 at 10:30 AM
    bzzr2
    There is a lot of info about skinny 33's and how the fit. Dig around the site. Don't take much of what you read for fact here either! If you can fit the tires with a lift, they will fit stock. Under compression lifted or stock there is the same amount of room for the tires. People on this site will argue back and forth all year long about shit they don't have real experience with. In my case I am 3rd gen, I believe there is a slight difference in front for ride height in stock form from the 2nd gen. If you don't want skinny 33's then the others that say cutting required are absolutely correct.
