33 inch tires rubbing
Discussion in 'Wheels & Tires' started by lilsmallz77, Jun 9, 2023.
  1. Jun 9, 2023 at 12:24 PM
    lilsmallz77
    lilsmallz77 [OP] Member
    I lifted my truck with 6112 up front and 5100 in the rear. I’m running the 6112 at max setting on both sides with a rear one inch block. The rear sits a half in higher than the front. I’m debating if I should put a 1/4 top hat spacer (which I think equals a 1/2 lift) or drop the rear down a half inch. I’m considering raising the front the half inch since my 285/70/17 Toyo MT with a -12 offset rub every time I turn. I did a CMC and am waiting on my new UCA Camburg C joint to arrive to hopefully help some how. Maybe a wheel spacer? The issue is the tread of my tire is rubbing against the bottom of my plastic bumper and I’m afraid the tires while win in that fire I don’t want it to crack my plastic bumbler. Anyone with advice please help! I’ve already multi tooled the fender but it’s hitting the metal bracket and bolt where the plastic bumber attaches to the fender
  2. Jun 9, 2023 at 12:32 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    :sawzall:
    it’s your alignment…need a better one
  3. Jun 9, 2023 at 12:36 PM
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    The reason for rubbing is that you changed the offset to a -12 effectively pushing the tire further out, and between moving the tire further out and putting on a wider than stock tire, you have essentially created a longer pivot radius for the tire. As a result, even with the CMC, you have rubbing. UCAs will not fix the rubbing issue, as they will likely set the tire further to the rear when adjusting caster as close to spec as possible.
    Two fixes
    1. change wheel offset back to stock (new rims or factory rims).
    2. go higher on the lift (probably a 3/2 front to rear) to get the required clearance for the pivot radius of the tire.
  4. Jun 9, 2023 at 12:38 PM
    AllTacosFloat
    Boston ish
    Lift doesn’t fit bigger tires on a taco:bananadead:
    i had skinny 33s with no lift
    sanchez and DavesTaco68 like this.
  5. Jun 9, 2023 at 12:41 PM
    lilsmallz77
    Thank you I will probably go higher like I said the rear is a 1/2 taller so I’m thinking raise the front a rear does that entail a 1/4 or 1/2 top hat spacer?
  6. Jun 9, 2023 at 12:42 PM
    lilsmallz77
    That’s what I’m hoping I’m in the possible with stock UCA once my new ones come they’ll allow more negative camber and Casper what do you recommend? Someone said -4
  7. Jun 9, 2023 at 12:44 PM
    svermilyea
    Scott
    East Tennessee
    You are incorrect. Lift overcomes wheel offset as the center of rotation is below the lower side of the body.
    BC Hunter likes this.
  8. Jun 9, 2023 at 12:45 PM
    AllTacosFloat
    Boston ish
    At least 3.6 , 4 is great
  9. Jun 9, 2023 at 12:48 PM
    AllTacosFloat
    Boston ish
    Ok, been thru this plenty.
    You’re right I’m wrong.
    my suspension compresses back to stock height like every other taco I’ve seen.
  10. Jun 9, 2023 at 11:11 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Check out the video
    https://youtu.be/33VewJFda1Q
    sanchez likes this.
  11. Jun 19, 2023 at 4:27 AM
    sanchez
    sanchez Off Road Member
    Shawn
    Ontario Canada
    sr5 Trd Off Road
    Coverking cr noeprene seat covers, Compustar remote starter, Husky X-act fit floor liners, ARE cap, bed mat, 17"DAI Storm wheels, Goodyear Dura Trac tires, 20%tint
    math ..who knew ?
