33 inch tires, what gears should i go?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoNinja12, Oct 8, 2008.
  1. Oct 8, 2008 at 4:07 PM
    TacoNinja12
    TacoNinja12 [OP] Well-Known Member
    Boone NC
    99 2.7L SR5
    3 inch lift
    So i've got a 2.5 inch lift in my closet, and i want to put on a 3 inch body lift with it. I'm thinking some 33s will feel good but i dont know what gears to go with. i want to have some power and pretty good gas. I have a 99 sr5. no additions yet.
  2. Oct 8, 2008 at 6:14 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I would say you could stay with what you have. I had an 02 prerunner and had 3.91 rear gears.
  3. Oct 9, 2008 at 8:14 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    depends on what you have... I listed the factory gear chart somewhere in here and it tells you how to find your factory gears... some guys have 3.91 some have 4.10 some have 4.30... really the 4.30's with 33's would be a good combo.. 4.56 would be ok but would run high rpm on interstate
