33" on billies set at 2.5"????????
Discussion in 'Wheels & Tires' started by StormTroopinTaco, Feb 6, 2013.
  1. Feb 6, 2013 at 8:44 AM
    StormTroopinTaco
    StormTroopinTaco [OP] Member
    Dan
    Pensacola, FL
    2016 Inferno Red TRD Sport DCSB
    I recently had billies put on my truck and the front is set at 2.5" and 1.75" AAL in the rear. I am needing to know before I purchase tires if I can fit 33" with that setup. And if so how much rubbing if any? Please if anyone has done this setup before, please help me out on if this is possible or if I should just get 32s. Thanks!!!
  2. Feb 6, 2013 at 8:48 AM
    Taco Libre
    Taco Libre Well-Known Member
    JohnnyHildo
    Saskatoon, SK
    2008 Black 4x4 Access-Cab TRD OffRoad
    Rear TSB, 5100s @ 0, Toytec 3" lift, Total Chaos UCAs
    i would imagine you could fit them in but its going to be rubbing for sure. most guys will need a 3" lift to do this and still have rubbing in certain situations. many advise a cab-mount chop even with the suspension clearance.
  3. Feb 6, 2013 at 7:16 PM
    veet skeet
    veet skeet Well-Known Member
    Cali
    14 4Runner Trail Edition MGM
    Bilstein 5100s, 17' Method NV Race Wheels, Goodyear Duratrac 265/70/17, Demello Sliders, Xenon/LEDs All Around, Dark Window Tint, Gobi Roof Rack (In the Mail), JL Audio Subs, Alpine Speakers and Amps
    I did this without any lift in the back. I had to do a cab mount chop and a lot of fender plastic trimming and it would still rub full lock sometimes or flexing. Get OME 885x coils and set 5100 at .85 like I did and you won't have as much of an issue
  4. Feb 8, 2013 at 11:05 AM
    NBRobert
    NBRobert Member
    Robert
    Newport Beach
    06 TRD Access Cab
    I didn't do anything to the back and put the Biily's up all the way in the front. All I did was take the front mudflaps off; only time I get rubbing is when I hit a bump quite hard at full turn. This is with 285s.
