33" on Stock Suspension- nope
Discussion in '1st Gen. Tacomas (1995-2004)' started by fsbrain03, Feb 26, 2010.
  1. Feb 26, 2010 at 10:24 PM
    fsbrain03
    fsbrain03 [OP] Well-Known Member
    I just purchased some 285/75/16 Goodyear MT/R with Kevlar, on a set of Dick Cepek wheels. As I found out tonight, the 33's will not work stock. There is a lot of rubbing in the front, when i barely turn the wheels. Luckily I have a kit coming in: 3" front and 1.5 rear.
    A question: Will the above lift fix my rubbing problem, or will I need to do some body work? If body work is needed, what do I need to do? I see a lot of trucks on here without the mudguards, does that help reduce rubbing? What is best to remedy rubbing?
    Thanks
  2. Feb 26, 2010 at 10:31 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    whats the backspacing on the dick cepeks
  3. Feb 26, 2010 at 10:44 PM
    fsbrain03
    4.09"
  4. Feb 26, 2010 at 10:47 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    I think you will be ok once you have your lift in, you may have to remove the front mud flaps though. Someone else with this exact set up will probably chime in and give you some good advice. Good luck with it and post a few pics when its done.
  5. Feb 26, 2010 at 10:50 PM
    fsbrain03
    Thanks, and I should have lift in next week.
  6. Feb 26, 2010 at 10:51 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    what lift are you planning to run?
  7. Feb 26, 2010 at 10:54 PM
    fsbrain03
    I bought this last night 3" spacer upfront, and add a leaf in rear (1.5-2").
  8. Feb 26, 2010 at 10:58 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    pre load spacer or top mount spacer?
    3" up front will clear the tires with 4" backspace... when you get your alignment done, see if they can set your caster 1.5 to 1.7 degrees forward to keep the sidewalls from rubbing the pinch weld on turns...
  9. Feb 26, 2010 at 11:02 PM
    fsbrain03
    They are top mount. Great ideas on the alignment part.
    So, no body cutting should be needed after I complete the above?
  10. Feb 26, 2010 at 11:04 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    u should be fine...
  11. Feb 26, 2010 at 11:06 PM
    fsbrain03
    Great! I'll wait to get the lift on, get the alignment, and go from there.
    Thanks again.
  12. Feb 26, 2010 at 11:30 PM
    xSpyderguyx
    xSpyderguyx Well-Known Member
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    s40 Flowmaster 33" Toyo M/T tires 16" P.A wheels 3" revteck Suspension lift
    You will rub on "hard-over" turns and when mudding. A buddy of mine has 285's and a 3" lift and he rubs. Not significantly but on sharp turns and bumpy ass roads.
  13. Feb 26, 2010 at 11:31 PM
    xSpyderguyx
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    But depending on the spacing, you could just barely clear it. Good luck man;)
  14. Feb 27, 2010 at 6:40 AM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    That lift will work fine with those tires. You might rub a tiny bit, but nothing to seroius, it'll look good too, just don't forgot to put some pics up when you got them all mounted
  15. Feb 27, 2010 at 9:30 PM
    fsbrain03
    I was playing around today, and put the new 33's on before the lift. I then, put the jack underneath, and raised about 3". After removing the front flaps, the tires still rubbed a little of the inside of the fender flare. Can I trim the flare, without trimming the truck body? Doesn't look like i'll have to trim much, but may have to. Thoughts?
    I took some pictures of how the truck looks today, so I'll post them in a few. And then, post some after the lift and new tires.
    Nsane1 likes this.
  16. Feb 28, 2010 at 6:30 PM
    Mskotch
    Mskotch Well-Known Member
    mike
    litchfield,ct
    02 trd v6
    3"toytech lift 285 m/t's w/ toyota tundra wheels grillecraft billet grille 10k HID'S tinted tails fog-light mod westin ultimate series b-bar custom 5 on 5% tint-all around w/ strip debadged ..much more
    you will be fine. i have a 3" toytech lift, and just put 285/75r16 m/t's on my taco this past monday and i have no rubbing isues at all, and im on stock tundra rims.
    and as mentioned, make sure to get some pictures.
    mike
  17. Feb 28, 2010 at 6:44 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    i have 285's and a 3" suspension lift and i dont rub at all on full lock turns but i did rub a little against the cab but i fixed that by bending the metal so now i have no rubbing at all even when off-roading.
  18. Feb 28, 2010 at 6:58 PM
    fsbrain03
    All of these comments are making me excited to get that lift in. It should be here Wednesday sometime.
    Thanks again for everyone's help.
