33" or 35" Toyo MTs
Discussion in 'Wheels & Tires' started by KMN-BLU, Apr 23, 2009.
  1. Apr 23, 2009 at 8:08 AM
    KMN-BLU
    KMN-BLU [OP] less work/more play
    Destin, Fl
    2018 Tacoma TRD PRO
    I am going to be installing my 6" ProComp Stage II lift here soon.
    I have selected the lift and selected my required 18" wheels.
    The only question left is should I go with a 33" Toyo Open Country MT or should I pick the 35" Toyo Open Country MT?
    Will I really lose that much power or gas mileage between a 33" and a 35" tire? I think the 35" will look better but dont want to make to many sacrifices for the look. The 4x4 shop will charge me $10 more per tire for the 35s.
    Any advice or opinions on which I should chose and why?
  2. Apr 23, 2009 at 8:10 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Based on price alone I would go with the 35's.
    I however have no experice with them in any other way on our tacomas.
  3. Apr 23, 2009 at 8:21 AM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    35s!!! You'll love it!
  4. Apr 23, 2009 at 8:23 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    If its for looks, than the 35's definitely!
  5. Apr 23, 2009 at 8:30 AM
    KMN-BLU
    Destin, Fl
    2018 Tacoma TRD PRO
    Its not all about the looks. Its also about whether the tradeoff of gas mileage and power worth jumping up to a 35" tire.
    35 looks better than the 33 but looks aint everything when you are already spending 5-6k,
  6. Apr 23, 2009 at 8:33 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I would have to say 35"s since you are getting a 6" lift. Be aware because even though you are going up 6"s, I've heard that there is still a bunch of trimming involved for them to work right. Might want to ask the 6" guys.:rolleyes:
  7. Apr 23, 2009 at 8:38 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    35's will require modifications to the body mounts to avoid rubbing. Check SilverSeven's build.
  8. Apr 23, 2009 at 8:52 AM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    35s!!!
  9. Apr 23, 2009 at 9:03 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    33" no rubbing no trimming no issues off road.
  10. Apr 23, 2009 at 9:09 AM
    stevomac59
    stevomac59 Is mod CraZy...
    Laredo, Texas
    07 PreRunner TRD
    3'' lift, custom stereo deck, 33'' toyo Mt tires, 17'' MotoMetal Rims, 20%Tinted front Windows, 5% Rear Windows, Blacked out Grille Surround, Bull Bar, HID Head and Fog lights, KC Daylighters, BHLM, Strobe Lights, Sockmonkey TRD 3rd BreakLight decal, 12'' MTX Thunder Subwoofer, 1000Watt Planet Audio Amplifier, Flowmaster Muffler Xhaust S40
    For $10 additional for each tire for 35's is a DAMN good deal.. However, Milleage will be different (b/c toyo's are heavy tires)...I have 33's on my truck, they look big and are very durable...35's would look sick with a 6'', but if you are worried about mileage and rubbing, you should go with 33's
  11. Apr 23, 2009 at 9:17 AM
    LiftedForLife
    LiftedForLife Active Member
    Massachusetts
    09 TRD DoubleC SB
    You could have fit 33's with a 3" lift. Why stop now, go with the 35's, it will look much better with 6" lift. The milage loss between 35's and 33's will be pennies compared to the cost of buying 35's to replace your 33's if you regret the decision.
  12. Apr 23, 2009 at 9:18 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    35's for sho
  13. Apr 23, 2009 at 9:20 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Well with a 6" lift there wont be much gas mileage to salvage
  14. Apr 23, 2009 at 9:34 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    unless he regears
  15. Apr 23, 2009 at 9:50 AM
    SuperD
    SuperD Mall Cruiser Pilot
    Texas
    '09 White TRD Sport DC LB 4x4
    ProComp 6" Stage II, 18x9 Moto Metal 955's, Cooper Discoverer STT 305/60R18, K&N FIPK, Go-Rhino Stainless side steps, Redline Elite hood struts, Magnaflow muffler, Delta Alum. Toolbox, Husky Liners F/R, Window tint
    I don't think how much lift you have determines if you need to regear...tire size is what matters :confused:
  16. Apr 23, 2009 at 10:01 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    i kno but im saying that if hes going that much of a lift and if he decides to go with bigger tires then if he regears he will get better mpgs
  17. Apr 23, 2009 at 11:09 AM
    KMN-BLU
    Destin, Fl
    2018 Tacoma TRD PRO
    4X4 shop says that once they are mounted (35s) there aint no taking them back. So, if they mount them and they rub then I will end up having to cut stuff to make them fit. Not feeling that right now.
    Its a delima now. Stay with the safer 33 that fits, or go for the 35 and risk some rubbing. ProComp says it will fit without rubbing but its a tough risk to accept.
  18. Apr 23, 2009 at 11:13 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    i say mount them and if and only if they rub buy a 1 inch body lift and have the shop put it on
  19. Apr 23, 2009 at 11:19 AM
    SuperD
    Texas
    :D This is just my opinion, but with the luck I've had with info from ProComp......I wouldn't trust one effin' thing they say.....lol
  20. Apr 23, 2009 at 12:15 PM
    dabighi
    dabighi Well-Known Member
    from the trucks ive seen, the trimming isnt too bad to get the 35s to fit. just remember that runnin the 35s your gonna have to regear at some point cuz you wont get up past 70.
