33"s on stock lift?
Discussion in 'Wheels & Tires' started by f1trider35, Feb 16, 2010.
  1. Feb 16, 2010 at 6:20 PM
    f1trider35
    f1trider35 [OP] New Member
    Rancho Cucamonga,CA
    2003 PreRunner SR5
    Quick question.. Will 33" BFG all terrains fit on my 03 doublecab prerunner sr5 with no lift?
    -thanks
  2. Feb 16, 2010 at 6:56 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    :rolleyes: No they will not work bro to run 33's you have to get at least a 3 inch lift and at that you might have to do some trimming.
  3. Feb 16, 2010 at 6:59 PM
    meckleystephen
    meckleystephen My Taco is Bi-Winning!!!!!!!!
    Stephen
    York, PA
    2013 Toyota Tacoma Off Road
    3 Inch Toytec lift,Blacked out badges
    i had a 96 taco with a three inch lift and 33's still rubbed it sucked
  4. Feb 16, 2010 at 7:00 PM
    KentuckyTaco
    KentuckyTaco Well-Known Member
    P-Town
    02 xcab 4x4
    K&N filter w/deckplate mod Dynomax muffler Tinted windows Maglite mod Line-x spray in bedliner Blacked out taillights/3rd brake light
    nope sure wont, i could only run about a size bigger than factory with my stock lift but, i got a of mud tires
  5. Feb 16, 2010 at 7:59 PM
    f1trider35
    Rancho Cucamonga,CA
    2003 PreRunner SR5
    What if i get lift spindles in the front? Will the back rub too?
  6. Feb 16, 2010 at 8:05 PM
    tacomakid96
    Phil
    Out n' about
    Im not sure my gut feeling would be no I know that they will probably be pritty tight in the rear to. If you want to run 33's with a fairly low cost and you dont care about the ride quality you could run a 3 inch spacer lift with aal or blocks in the back with a little trimming.
  7. Feb 16, 2010 at 9:33 PM
    texasbowhunter
    texasbowhunter Third Coast
    Texas Gulf Coast
    04 Double Cab 4x4 TRD
    Tinted Windows, Moto Metal 955's, Cooper 305/70/16 STT's, Deckplate Mod.,AFE Pro Dry, Toytec Coilovers, 2" AAL, Diff. Drop, Bilstein 5100's On the Corners, Alpine 10" Sub, Alpine 305 Head, Polk Mids
    If I were you I would get the adj. 5100's and an aal if you are on a budget. I don't think you would be happy with the spacer lift. If money is not an issue I would get a CO lift by Toytec or OME.
  8. Feb 16, 2010 at 9:47 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    No way.
    These are 33.4" on a 3". So imagine how JAMMED they would be on a stocker
