33" tires (50-55lb) or 34" tires (60-67lb)?
Discussion in '4th Gen. Tacomas (2024+)' started by Droid, Apr 2, 2025.
  1. Jun 11, 2025 at 6:29 PM
    Phadreus
    Phadreus Active Member
    Mark
    '25 Tacoma TRD Sport
    Center of mass should be directly on the axis of rotation, varying only in longitude along the rotational axis depending on rim offset. Distribution of weight is a concern, but I don't believe I could obtain enough information from any of the manufacturers to go much further than what I've done so far. If I had a decent model of the wheel and tire, I could apply mass properties and provide a much more accurate model.
    OpeCity[QUOTED] likes this.
  2. Jun 11, 2025 at 8:52 PM
    Droid
    Droid [OP] Well-Known Member
    22 Pro 6MT #FFFFFF
    Thank you for the awesome calculator!
    I still don't have the truck, but am leaning toward going with the 34s as it has the OEM lift. The Toyo A/T3 in LR C is current frontrunner, lightest option for a good 34 I can find at 59lb.
    I'll be going up 55% in rotational inertia if I stay on stock wheels. But only some of that is fair given that the OEM tires are 36lb, which is absurdly light and just plain inappropriate for the vehicle. A reasonable baseline would be a BFG KO2 in 265/70R17 load range C, at 46lb. In that case I'm up 35% in rotational inertia. If I run RRW 20lb wheels...that number would fall 39% over stock with "fake" tires or 20% over stock with "reasonable" tires.
  3. Jun 11, 2025 at 9:13 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Yeah I guess I mean a rough approximation of the mass distribution as a single weight and diameter number. Not center of mass. I’m not engineer enough to know how to say it :rofl:
