33" tires RUB
Discussion in 'Suspension' started by 2010TRD, Feb 2, 2013.
  1. Feb 3, 2013 at 5:40 PM
    2010TRD
    2010TRD [OP] Well-Known Member
    Thomas
    Waldo, FL
    2010 MGM trd offroad DCSB
    Billistein 5100 front/rears, Toytec 2" AAL Custom grill, All Pro rear bumper, All Pro sliders, Anytime elocker/foglights, Rear diff vent relocated, W/O seat covers, weathertech mats/visors, nfab tire racK, cobra 75 stealth CB, Custom engine/trans skids 3/8", Hella and HID behind grill, LED bar backup light, LED pods under cab (rocklights)
    X2 ??
  2. Feb 3, 2013 at 5:41 PM
    2010TRD
    Thomas
    Waldo, FL
    Colin what's your thoughts on shifting the bed forward ..as mentioned by previous posts ..?
    I think I may try this
  3. Feb 3, 2013 at 5:49 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    if you loosen all 6 bed bolts, you will have some play to shift it around. the success you have will be dependant on what direction your bed has freedom of movement in. the tollerances on these trucks as far as bed and body alignment goes is not very tight, so this method may work for some but not others. it's easy enough if you have a t-55 torx bit, so you might as well go for it.
  4. Feb 3, 2013 at 6:06 PM
    2010TRD
    Thomas
    Waldo, FL
    I planned to install d-rings anyhow ... So I'm gonna try this option ...
    Either way I'm gonna do bump stops eventually
    If you still have troubles getting rid of those 16" steelies ..lmk I will take them
    I'm trying to put together a set of highway tires for road trips .. Save some gas on long hauls ;)
  5. Feb 4, 2013 at 5:22 PM
    2010TRD
    Thomas
    Waldo, FL
    Problem solved ... For now
    I was able to shift the bed forward slightly .. This allowed the needed clearance and the factory bump stops are now the first thing to touch :yay:
    Still plan to lengthen bump stops
    Idea : I want to add length to bump plates (on frame)
    Maybe use some grade 8 bolts to lengthen the plates
    It's hard to explain my idea with words
    I will attempt to craft this idea ..and take pics and post
    Hope to have time this week to do this mod
  6. Feb 4, 2013 at 5:24 PM
    2010TRD
    Thomas
    Waldo, FL
    Thanks for this suggestion .. It worked for me and makes me feel better about going offroad this coming weekend
    :thumbsup:
  7. Feb 4, 2013 at 5:25 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    how close is the bed to the cab after you moved it forward?
  8. Feb 4, 2013 at 5:41 PM
    2010TRD
    Thomas
    Waldo, FL
    It really didn't change the body gap much at all ... To the eye, you can't even tell
    Still plenty of room for body flex , I see no concern with potential impact
    I highly recommend this free mod ... :thumbsup:
