33'' tires with a 2.5'' lift am I crazy?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomakid96, Jul 17, 2010.
  1. Jul 17, 2010 at 8:23 PM
    tacomakid96
    tacomakid96 [OP] Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    I have been working all summer and have money for the Taco! I want bigger tires now that my truck is lifted, I am thinking about getting some 33x10.50x15 Toyo MT's. I realize I would have to do some cutting but how much and what kind? The tire is actually 32.8'' tall any help or pictures of cuts would help me out.:D
  2. Jul 17, 2010 at 8:31 PM
    tweekson
    tweekson CRAZY
    Charlotte
    08 Tacoma TRD Sport
    3" Rough Country Lift, Leer 100R Cap w/ Slider Windoors, Baby Seat
    I got a 3" rough country lift kit for my truck....put 33's on it as well. I removed the mud flaps and had to do a little cutting in the front wheel wells. Minor cutting on the fenders I took an box cutter to the truck and within 2 or 3 minutes I was not rubbing anymore. I will send some picts tomorrow
  3. Jul 17, 2010 at 8:43 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    first gen vs second gen, its a whole different animal.
  4. Jul 17, 2010 at 8:49 PM
    tacomakid96
    Phil
    Out n' about
    my uncles has 285's and I compared them with my tires on my truck now and I would have to do trimming for sure, but I dont know what kind, and the new tires I want are narrow for a 33
  5. Jul 17, 2010 at 9:54 PM
    bighungitacoma
    bighungitacoma Well-Known Member
    i have a 1st gen with a 3" lift on 33/10.5s and have no rub issue at all, did not even need to trim anything
  6. Jul 17, 2010 at 9:54 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You might be able to get away with that tire but whether you do will depend a little on how much backspacing/offset the wheels have. If you intend to put those tires on a stock rim you'll likely see more rub compared to a rim with less backspacing.
  7. Jul 17, 2010 at 11:53 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    i have a 3'' lift with 33'/12.50 !!!!! So no you re not crazy
  8. Jul 18, 2010 at 12:07 AM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    heres a pic of the tires
  9. Jul 18, 2010 at 1:41 PM
    tacomakid96
    Phil
    Out n' about
    My rims have alot of offset they stick out of my wheel well a inch or two so I dont think I would have to put a spacer on.
  10. Jul 18, 2010 at 1:42 PM
    tacomakid96
    Phil
    Out n' about
    Truck looks awesome brian I like the tires and truck so much!!
  11. Jul 18, 2010 at 8:29 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    Awesome.
  12. Jul 19, 2010 at 5:05 PM
    tacomakid96
    Phil
    Out n' about
    Brian did you have to trim your front valence?
  13. Jul 19, 2010 at 6:51 PM
    takern
    takern Well-Known Member
    Tanner
    Virginia
    03 TRD Offroad stepside
    Deckplate mod, sliders, uniden cb, toolbox, dakar leaf pack, in search of coilovers, 255/85 16 bfg m/t waiting to go on
    i have 2.5" SAW coilovers up front with 255/85 16 tires and did not have to cut at all. the only time they rub is at full lock. i just dont turn all the way
  14. Jul 19, 2010 at 7:01 PM
    buckshot85
    buckshot85 Member
    Hampton S.C.
    02 prerunner SR5
    flowmaster super 44 halogen lights procomp extreme mt 285/75/16 procomp wheels revtech 3in lift 20% tint westin steps
    i've got an 02 with 3" lift with 285/75/16 and had to trim the rear above the mud flaps about 1/4" even though i took the mud flaps off
  15. Jul 19, 2010 at 7:17 PM
    tacomakid96
    Phil
    Out n' about
    Cool this has really helped me out so far guys
