33" Winter tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crx7, Mar 20, 2019.
  1. Mar 20, 2019 at 9:52 AM
    crx7
    crx7 [OP] 1997 FZJ80 Triple Locked
    Grand Junction Colorado
    So, I have 265 70 16 Bridgestone Blizzaks on my Tacoma. These are unstoppable here in Colorado and will get me to ski resorts on icy roads in the middle of a blizzard. Thus, I like having a dedicated winter tire.
    However, I'd like to upgrade my summer tires and was very interested in a 255 85 16. I wanted this size as it's a little lighter 33" tire than the 285 75 16. I'm already carrying a lot of camping weight and didn't want to drop my mileage that much.
    KM3 in 255 85 16 should be out this month, and I was about to pull the trigger as it's spring, but there is no 255 85 16 winter tire. Does anybody out there switch between diameter tires for winter and summer? I would surmise this would require an alignment every time i switch.
    Closest compromise is going with 265 75 16 tires which there are plenty of options for, or 285 75 16 for winter and summer, which is a big heavy tire.
    timbobzimbob likes this.
  2. Mar 20, 2019 at 11:25 AM
    Johnders
    Johnders Spacer Lift Survivor
    2010 Black Access Cab Tacoma Base
    2" Lift , 265/75R16 tires, K& N filter, MBRP Exhaust
    I could be wrong but tire size differences shouldn't effect alignment. I have never heard people getting an alignment after getting bigger or smaller tires alone. I imagine you would be fine using your existing winter tires and just swapping your new skinny 33's on in the warmer months.. It should only effect your speedometer and your MPG slightly.
  3. Mar 20, 2019 at 1:01 PM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    The general rule of thumb is when you buy new tires to get your alignment checked/adjusted in case it's slightly out of spec in order to prolong the life of the tire. It's not a requirement to get one, though.
    4WD FTW likes this.
  4. Mar 20, 2019 at 1:05 PM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Why run the risk of it being out of spec and chewing up the new tires prematurely? Get the alignment when you get new tires.
    Beretta4x4 likes this.
  5. Mar 20, 2019 at 1:21 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I haven't needed an alignment in over 20 years. I've been driving since the 1970s and only needed it done to one truck that was wearing tires unevenly. I'm on my 5th set of tires on my 12 year old Tacoma and it has never been touched since leaving the factory and the tires still wear evenly. Some of you guys just like to spend money.
    We don't do winter/summer tires in GA so I can't help with that. But I do like the look of 255/85/16s on a Tacoma. My truck came with P series 265/70/16s. Over the last 195,000 miles I've had 245/75/16's and 265/75/16's in both P and E rated tires. The factory tires weighed 38 lbs, the E rated tires on it now weigh 53 lbs. Fuel mileage and performance is exactly the same today as it was the 1st tank of fuel.
    The 285's may well hurt fuel mileage somewhat because they are a wider tire that has more rolling resistance. Not because they are heavier. The 255s may well get the best fuel mileage for the same reason. But you'd probably have to carry the decimal point to several places to show the difference. It is the tread design that will determine any loss of fuel mileage. As long as you stay with a mild AT tire you'll be fine. Go to an aggressive mud tire and you'll lose 2mpg regardless of the size you choose.
  6. Mar 20, 2019 at 1:24 PM
    Beretta4x4
    Josh
    Temple, TX
    You do you. It's good proactive maintenance.
  7. Mar 20, 2019 at 1:26 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Do you wheel your truck or drive a lot of gravel roads?
    I find these trucks lose alignment easily. One good deep pothole out of no where and it can shift.
  8. Mar 20, 2019 at 1:27 PM
    Beretta4x4
    Josh
    Temple, TX
    I mess with my suspension periodically and I wheel and I find that I have to adjust my alignment frequently.
  9. Mar 20, 2019 at 7:48 PM
    crx7
    If you leave it stock, and nothing major changes, you probably don't need an alignment. However, I've had my alignment done when I've done major things like control arm changes and lift. After these changes the alignment was definitely off.
    Thanks guys, I'll just pull the trigger on the 255s.
  10. Mar 20, 2019 at 9:40 PM
    4WD FTW
    4WD FTW Well-Known Member
    '08 DC LB 4x4
    Icon Suspension Kit Pelfrey Bumper and Skid 4.56 Gears Detroit TruTrac Rear Archive Hammer Hangers Deaver U402 Stage 1
    I haven't had mine aligned in a year and just noticed the fronts are cupping on the inside edges. Kinda sucks. To be fair the LCA bushings are going bad, which ceetainly affects how it stays in check
  11. Mar 20, 2019 at 10:19 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Changing tire size does not require an alignment.
    All you’re suspension components stay in the same place. The alignment doesn’t change.
    Johnders likes this.
  12. Mar 20, 2019 at 10:27 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Load range is a factor to consider if your worried about weight. The 255/75/16 st maxx only come in E range. I'm sure you could find a lighter 285 in a C range
  13. Mar 21, 2019 at 6:24 PM
    crx7
    I carry a 1000lb slide in camper from time to time and want the load range E
    Reh5108 and Beretta4x4 like this.
