33 woes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sep1911, Oct 14, 2015.
  1. Oct 14, 2015 at 9:43 AM
    Sep1911
    Sep1911 [OP] Well-Known Member
    2016 Taco
    So I have a 5 piece set of 33s from my previous vehicle and I figured I'd try to put them on the taco to see how they fit. Apparently you can't fit 33s on 2nd gen without mods but I figured I'd try it on the 3rd gen since the wheel wells look like they can barely fit 33s.
    Well, my wheel swap was short lived. I tried mounting one of the 33s and since they are on Isuzu alloy wheels the calipers were hitting the walls of the wheels as the walls taper in. Kind of bummed with the taco because fitting 33s is a pain in the ass.
    I'm trying to figure out how to approach this. I'm currently not worried about up travel rubbing because the taco will be seeing pavement for the time being until I get a lift, then I'll be hitting the trails. Seems like I could get the 33s mounted if I install wheel spacers but I'm generally not a big fan of them. But I do like these wheels. These 33s are on 16x7 wheels by the way. Anyways, would spacers or maybe wheels with less back spacing resolve issues with the tires rubbing on the suspension parts? I was thinking about getting 16x8 steelies with 2" back spacing.
    Any input?
  2. Oct 14, 2015 at 9:45 AM
    Sep1911
    2016 Taco
    Can someone delete this?
  3. Oct 14, 2015 at 9:48 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    id start by getting the correct wheels
    0uTkAsT and KB Voodoo like this.
  4. Oct 14, 2015 at 9:54 AM
    Sep1911
    2016 Taco
    The 33 wheel will fit and clear the caliper with a 1" spacer. But either way I need to know if less will be helpful because if I get wheels I'll need to order the correct specs
  5. Oct 14, 2015 at 10:17 AM
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    You have a $30k+ brand new truck. Don't short change it by putting on wheels that don't fit. Spacers or not.
  6. Oct 14, 2015 at 10:19 AM
    Sep1911
    2016 Taco
    So help me by figuring out what back spacing I should get for 16x8 wheels.
    Would 4" back spacing suffice or do I need less?
  7. Oct 14, 2015 at 10:21 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    You need 4" of backspacing
