33's, armor, fridge, camping equipment, etc- 4.30 vs 4.56 gears
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sna, Mar 19, 2019.
  1. Nov 13, 2019 at 7:11 PM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    On the highway at 70, I’m getting roughly 15.5-16 mpg if that makes you feel any better. I’ve done multiple tanks of gas on interstate so those numbers are fairly accurate.
    Sna[QUOTED][OP] likes this.
  2. Nov 13, 2019 at 7:15 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    I have the same truck, full armor bumpers, skids, rear bumper with dual swingouts, sliders, roof rack and running 255/80/17 Coopers. I pull a micro off road camper with it on and off road. Yes there was a little powr loss but it does absolutely fine even towing the camper with stock gears. I don't mean fine as in it's ok and I can live with it I mean it tows like there's nothing behind it most of the time hills are the only time I notice the added weight of the camper and I just drop a gear. A bennifit of the MT being geared lower i guess.
  3. Nov 13, 2019 at 7:19 PM
    Sna
    Sna [OP] Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    That does make me feel better. Right now I’m getting about that same mpg. Over the summer I tested running several tanks of gas in 5th gear on the highway to see if the elevated rpms made a difference in mileage. Mileage between 5th and 6th gear really didn’t change but I think it was because the higher rpm’s caused the engine not to struggle so much.
  4. Nov 13, 2019 at 7:37 PM
    2big4arunner
    2big4arunner Well-Known Member
    Tyler
    Vernon BC
    2015 tacoma dclb
    3/2 leveling kit, 275/60r20 duratracs on xd128 20x9 rims, AFE stage 2 intake, trd exhaust, duel electric fan w/dakota digital controller
    you have to remember its also a different ratio at that point. check the current ratio to gear vs the new one.
    most fuel usage is related to throttle position vs rpm. but anything past half throttle to do anything uses very high air/fuel ratios.
  5. Nov 13, 2019 at 7:45 PM
    Jerneyman
    Wes
    Huntsville, AL
    Like what was just stated, you do have to remember to take in to account ratios when calculating fuel economy. When I gas up now, I’m multiplying my mileage by .9 to give me my corrected MPG. If I didn’t do that, I’d be getting large gains in MPG that really don’t seam possible.
  6. Nov 13, 2019 at 9:17 PM
    2big4arunner
    Tyler
    Vernon BC
    2015 tacoma dclb
    I hope your only adjusting your actual miles instead of the final figure. otherwise its not accurate
  7. Nov 14, 2019 at 3:53 AM
    Jerneyman
    Wes
    Huntsville, AL
    My math is accurate. Verified by GPS.
    Sna[OP] likes this.
  8. Jan 28, 2020 at 9:57 PM
    binge_stinker
    binge_stinker Well-Known Member
    2005 4X4 MT6 DCSB
    Power sliding rear cab window retrofit
    @Sna Did you end up regearing? I've been scouring threads looking for the best information and biased anecdotal evidence to help me pull the trigger.
    I'm a 6 speed on 285/75/17s and will likely step up to 35s after they wear out. Planning a long trip through UT after spring semester and won't feel comfortable hitting the road until I score front/rear bumpers, sliders, and lock the rear. I might as well regear while I've got the diff ripped apart and considering the extra ~500 lbs of weight I'll be adding.
  9. Jan 29, 2020 at 7:52 AM
    Sna
    Alberta
    I have not re-geared yet but it will be happening in the next 2-3 months. I still plan on going with 4.56 gears (and still Harrop lockers) even though I plan to stay with 33's and know I will be overgeared. My truck is as aerodynamic as a brick, will be heavy and I have plans to tow a small inflatable boat so this is ultimately the best direction for me.
    Seeing as you are adding weight (bumpers are also horrible for aerodynamics), your tires a just slightly taller than mine already and you have plans to go to 35's, I think you know which is the best direction to go. And I agree, if you have the 3rd out you may as well do the locker at the same time. Buy once, cry once!
  10. Jan 29, 2020 at 10:23 PM
    binge_stinker
    2005 4X4 MT6 DCSB
    Sna[OP] likes this.
  11. Jan 29, 2020 at 11:08 PM
    Sna
    Alberta
    So much to think about.....here is some more.
  12. Jan 30, 2020 at 2:30 PM
    Tbertrand
    Tbertrand Well-Known Member
    Travis
    Reno, NV
    2011 dclb
    id go 4:56, I went 4:88 but i have DCLB Auto. dont regret it at all. probably will regain some of that mileage too.
    binge_stinker and Sna[OP] like this.
