33s cause lots of stress on truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reto101, Jan 21, 2020.
  1. Jan 23, 2020 at 3:45 AM
    DG92071
    DG92071 Well-Known Member
  2. Jan 23, 2020 at 4:31 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Why would the uca change how it rides
  3. Jan 23, 2020 at 8:24 AM
    Ross4x4
    Ross4x4 Well-Known Member
    Taylor
    Mesa , Az
    2014 DCSB Silver TRD Offroad
    Typically you hear this after getting a lift to help with the alignment
  4. Jan 23, 2020 at 12:04 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    UCAs will allow for more articulation and further range of adjustment to correct alignment issues after a lift. Stock suspension components do not allow for further adjustments than what is required after modifying your suspension geometry.
    Caster, camber and toe is the determining factor in your ride quality, steering wheel to center characteristics and overall comfortability.
    Of course ride quality is subjective as it is dependent on your own personal preference but the majority of users on here that lift will always require aftermarket UCAs.
    You will find that ride quality substantially suffers with 2.5"+ lifts with stock UCAs and you will be subjecting the upper ball joints to the extreme spectrum of their operating range.
    Reto101[OP] likes this.
  5. Jan 24, 2020 at 9:51 AM
    Reto101
    Reto101 [OP] Member
    2008 Tacoma Prerunner
    Any recommendations of UCAs to buy? Not serious off roading just fun in the dirt with friends or going to the ranch every-once and a while. Mainly daily driving
  6. Jan 24, 2020 at 12:44 PM
    JKO1998
    Utah
    JBA or SPC
  7. Jan 24, 2020 at 3:39 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Depending on the rate of your tires. Yes mileage gonna take a hit. If all you do is highway driving you'll be ok.
