33's hard on transmission?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gitmo, Jul 15, 2013.
  1. Jul 15, 2013 at 4:29 AM
    Gitmo
    Gitmo [OP] Well-Known Member
    Justin
  2. Jul 15, 2013 at 4:48 PM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    33 inch tires like my 265/75R16 (or 265/70R17) are fine on a stock driveline with my stock 3.73 gears. If I was into serious crawling where I needed the added torque I would got to 4.56 gears and still be okay for highway use. Personally I need highway capability more that heavy duty crawling so I am sticking with my 3.73 gears.
    If you go to 35" tires (285/75R16) then a re-gear becomes more important so you still have the grunt to climb over stuff slowly. I feel the higher ratios have most benefit in giving you better control at low speed and in this case 5.29 gears are even better if running 35 or 37 inch tall tires.
    But for sure you need the same ratio in both front and rear differentials otherwise you are wasting power and loosing traction all the time, and on hard pack or pavement you will break something pretty quick!
  3. Jul 15, 2013 at 4:54 PM
    youradhere
    youradhere Well-Known Member
    SoCal
    08 Prerunner TRD Off-Road
    Could be wrong... you'd have to check my math but I think the 265/75/16s are actually less than 32"... 31.5 or something
    the 285/75/16's are 33"
  4. Jul 15, 2013 at 4:58 PM
    BamaToy1997
    Bill
    Navarre, FL
    Unless you want to damage your transfer case, NEVER select different ratio gears for your diffs. You want the same in the front and the rear.
    And yes, 265/75R16 are equal to 31.6 inch tires.
  5. Jul 15, 2013 at 5:01 PM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    ive ran 33's for a year and a half and over 30k miles of towing and wheeling...no issues
  6. Jul 15, 2013 at 5:35 PM
    Gitmo
    Justin
    Thanks for the replies everyone, I plan on going with 4.56's in the future. Would I be fine running 285/70/17 duratracs on stock gearset?
  7. Jul 15, 2013 at 5:51 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I've had 295/70/17 on my truck for 60k with stock gearing, no issues.
  8. Jul 15, 2013 at 5:54 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Yes, just a little more sluggish and your mpg will take a hit.
  9. Jul 15, 2013 at 6:21 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    don't ever go bigger than stock size
  10. Jul 15, 2013 at 6:37 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    :brianr:
    kingjj likes this.
  11. Jul 15, 2013 at 9:38 PM
    Desert Drifter
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Hey, thanks for the correction on my 265/75R16 Dura-Trac tires. A mild 31.6" tall but they do me well (so much better than the General street car tires that came on the truck) with stock 3.73:1 ratio differential gearing.
  12. Jul 15, 2013 at 11:19 PM
    brandonlamb25
    brandonlamb25 Well-Known Member
    Georgia
    08 Crewcab Prerunner V6
    K&N Intake, Wet Okole Seat Covers, Ipod to Factory radio hookup kit, Black Low Pro Toolbox, Toytec Coilovers and 285/75r16 BFG MT's
    I ran 285/75r16 for 70k miles. Half with stock gears then regeared to 4.11. More power (strength) after regear.
  13. Jul 16, 2013 at 12:45 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    http://www.ringpinion.com/Technical...eneralInfo//Myths_Regarding_Differentials.inc
  14. Jul 16, 2013 at 6:25 AM
    BamaToy1997
    Bill
    Navarre, FL
    Read the article, and yes, I would have to agree that a SMALL amount of difference might not be as BAD of a concern, but numbers can say a lot, real world application is where the truth is. 1% is not much at all, agreed. Admittedly I grew up in the wheeling world under 100% mechanical transfer cases with direct drive, and it was always a rule to never use different ratio gears. New tech has a bit more allowance, so yeah, as the article shows, 1-2% MIGHT be ok. I just figure get the same since they are usually equal in price anyway. Why take the chance?
  15. Jul 16, 2013 at 10:38 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Most transfercases have been pretty similar in design to ours for a long time. Part time, aluminum case, chain driven, direct drive with a low range option. The way you shift them maybe be a bit different but pretty similar. If anything the cast cases with gear drive were stronger and could hold up to abuse like that better -- NP205 for example. Just saying... You're right for our application, mixing gears isn't likely to happen but if you happened to find a deal on some very close but different 3rds, you could run em. That's all I'm saying.
  16. Jul 16, 2013 at 2:58 PM
    BamaToy1997
    Bill
    Navarre, FL
    Right, as long as the difference was never more than 2%. So no running 5.13 in the back, and 4.11 in the front! lol.
