33's on a 2nd gen leveled tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mbratten, Oct 2, 2018.
  1. Oct 2, 2018 at 4:37 PM
    Mbratten
    Mbratten [OP] New Member
    Hey! Does anyone know if 33 inch tires will fit on a 2009 tacoma with a leveling kit?
    Thanks!
    Stryker420 likes this.
  2. Oct 2, 2018 at 4:39 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Oct 2, 2018 at 4:40 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Define: "fit".
    Technically you will be able to mount them, but you wont be able to turn the wheel without rubbing everywhere.
  4. Oct 2, 2018 at 4:41 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    What's up guys? :wave:
  5. Oct 2, 2018 at 4:41 PM
    GHOST SHIP
    GHOST
    :fistbump:
    Mbratten[OP] likes this.
  6. Oct 2, 2018 at 4:42 PM
    geekhouse23
    *cracks knuckles* Looks like we got another one today...
  7. Oct 2, 2018 at 4:42 PM
    Stryker420
    Stryker420 Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Lots of work but you can clear 33s with just the leveling kit.
    Alexely999 and Mbratten[OP] like this.
  8. Oct 2, 2018 at 4:44 PM
    geekhouse23
    They will "fit" you might not be able to turn at full lock. I have a 3" lift up front and I have had to cut, trim and bash shit to death and I still rub Offroad.
    On the road, you can technically be "fine", but off pavement might be a different story.
    Wheel and tires specs come into play too.
  9. Oct 2, 2018 at 4:45 PM
    GHOST SHIP
    GHOST
  10. Oct 2, 2018 at 4:48 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I'll see myself out now.
    geekhouse23 likes this.
  11. Oct 2, 2018 at 4:48 PM
    geekhouse23
    :wave:
  12. Oct 2, 2018 at 4:48 PM
    Pigpen
    Dan
    Northwest Montana
    Define 33s
    My 255/85/16s are 33.5 with a narrow tread profile and hardly rubbed when the front was "leveled"(see what I did there?) with everything else stock up front.
    Edit: I run them on stock 2nd gen Tacoma steel wheels.
  13. Oct 2, 2018 at 4:50 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I am actually thinking of going with a skinny 33 in 17's
  14. Oct 2, 2018 at 4:50 PM
    GHOST SHIP
    GHOST
    OP, this is the most commonly asked question by new members. It's gotten to the point that even asking this question is comical (as you can already see). The short answer is "no" (unless you're willing to put in a lot of extra work to get them to fit properly, but the fact that you're even asking this question tells us that you're not willing to put in that extra work). Your options would be to go with a smaller tire or go with a bigger (actual) lift.
    Most of these types of questions can be answered with a quick google search in less time than it takes to sign up for a chat forum and start a thread.
    Welcome aboard. Don't let the hazing get you.
  15. Oct 2, 2018 at 4:50 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    How goes it Brother?
    geekhouse23[QUOTED] likes this.
  16. Oct 2, 2018 at 4:52 PM
    geekhouse23
    Just another day in the TW "neighborhood". You?
  17. Oct 2, 2018 at 4:52 PM
    Pigpen
    Dan
    Northwest Montana
    Did I mention I still get 17-18 mpg on said 33s? True story.
    geekhouse23 and Unchained 5150 like this.
  18. Oct 2, 2018 at 4:52 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I'm good and how are those Meso Lights treating you?
  19. Oct 2, 2018 at 4:55 PM
    geekhouse23
    Lights for daze (see what I did there?) :cool:
  20. Oct 2, 2018 at 5:17 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Doesn't really matter how much lift you have, that only helps you clear the tires at ride height. Your tires range of motion is still the same. When I was running 33s, they would rub the top of the inner fender when stuffed hard. 285/75/16 MTRs.
    https://youtu.be/egf7X4gHO2g
    Alexely999 and geekhouse23 like this.
