33s vs 32s how will my towing be affected
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zachwilson123, Oct 20, 2016.
  1. Oct 20, 2016 at 6:47 AM
    Zachwilson123
    Zachwilson123 [OP] New Member
    Zach
    2003 Tacoma Trd 3.4 rear locker 2wd
    5100 blistiens 881s 2inch AAL
    I can't decide between 33s an 32s I don't want the tires to stick out much atall an I'm keeping the stock rims an I have a 3 inch lift with 31s at the moment an how will my towing be effected ? Will I have to floor it up every hill an have to turn 4-5 thousand rpm to keep up speed? Cause right now I can keep it under 3 thousand the whole time I pull a bass boat probably weighs 1500 -200 pounds?
  2. Oct 20, 2016 at 6:59 AM
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    If you want the 33's you may benefit more from gettin a 255/85, thats a skinnier 33, so you wont get much of the tire sticking out, and i wouldnt expect it to change to much on the weight.
  3. Oct 20, 2016 at 6:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    tire calculator
    Play with the sizes/rpms
    The dia of the tire is what will change effective gearing. There is little to no 'stickout' by going taller as long as you select the correct width. Especially on OE wheels.
  4. Oct 20, 2016 at 8:47 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    if you have a auto your trans temps are going to be sky high when towing with that size tire and stock gears.
    Speedytech7 likes this.
