33's vs. 35's with 8 inches lift up front.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by con3boy808, Feb 13, 2011.
33's or 35's with 8 inches suspesion lift.
Poll closed Mar 15, 2011.
  1. 33's save the time chopping
    28 vote(s)
    36.8%
  2. 35's cut, cut, chop and hope it clears while wheeling
    48 vote(s)
    63.2%
  1. Feb 13, 2011 at 9:36 PM
    con3boy808
    con3boy808 [OP] Active Member
    Maui Hawaii
    Lifted Geared and Locked
    So how bout it how many of you get tire rub with the 6 inch kits with 35's?
    Mine does rub with the the Fabtech lift and 5100's set for an additional 2 inches of lift. But Im running 33/12.50's full compression and full lock. Rub is minimal on the body mount but is going to be substantial with 35's I know for a fact without chopping the mount.
    How many of you run 35's with the mount chopped and get tire rub on the mount. (Key is while in offroad use) I know some may say that they dont rub but are ignoring the fact/ living with it.
    I read that Krooks and Freedomrider swapped for 33 because of the rub but how many else have get it with the 35's
    Im debate with a new set of KM2's either 305/65/17 or 35/12.50/17 both tires the price and tire weight is the same or pretty close.
    Currently with my setup with the 33's and 4.56 gears puts me at 55mph at 2000 or so rpm/ about 200rpm over stock.
    Im leaning towards the 35s and willing to do the cut but is it worth it or is it gonna rub my fenders of the truck.
    Input and experience is appreciated.
  2. Feb 13, 2011 at 9:50 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    bigger is better right? I really don't know how much rubbing you'll have, but with 8" up front I would imagine the 35s will rub minimally. Thought I'd post somethin cuz nobody else was - hopefully someone with actual experience chimes in soon.
  3. Feb 13, 2011 at 11:37 PM
    kauaitaco69
    kauaitaco69 Active Member
    hawaii
    06 lifted white tacoma
    k&n intake, 40 delta flow exhaust, 6 in. lift, 20" centerline eclipse wheels with 33x13.5 iroks, pioneer deck, alpine type s components, one 12" alpine type R and 1000 watt alpine v-power amp.
    i think its the offset of the rims cause i got an offset of 4.5 and 33 13.5 tires and mine still rub the body mount on a 6in lift. i think 35s will fit if you got the right offset on your rim
  4. Feb 14, 2011 at 1:08 AM
    con3boy808
    Maui Hawaii
    ^^ I agree with the offset part but I have two choices. I run a 17x9 pro comp wheel with a 1.5 hub spacer most of the time for the wider track width. I guess I would have to try with and without. Without I just may clear but with hmmm...
    I was even thinking of adding the timberin's up front from allpro to help slow down the up travel a bit.
    If the Toyo MT's weren't so pricey 285/75/17 is what would be on there now.
  5. Feb 14, 2011 at 7:59 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    I always give them 8 inches up front. I don't hold back.
  6. Feb 14, 2011 at 8:01 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Go with 35s. 33's with 8 inches of lift will look so small...
  7. Feb 14, 2011 at 8:24 AM
    TACO2003
    TACO2003 Well-Known Member
    Doug
    Fayetteville, North Carolina
    2003 SR5 TRD 4X4 Black Tacoma
    6" Fabtech Suspension lift. Headers with dual exhaust. Flowmaster muflers. Engine Computer chip. Tiregate with spare tire. Mickie's TTC Claws 315/75R/16 tires. Dick Cepec DC II wheels. Shrockwork front winch bumper. 8,000 Lb Warn Winch. Heavy duty leaf springs. K&N cool air intake. Sprayed bed liner. Bushwacker flare fenders. 1/2" Steel plated rear bumper.
    I've got a 6" Fabtech lift with 35's and no issues. I just had the open bushwacker flared fenders installed which gave me even more room. I'm thinking about putting 37's on next year.The pic dosen't have the bushwackers on it.
  8. Feb 14, 2011 at 5:51 PM
    jek3fl
    jek3fl Well-Known Member
    Joey
    Jax, FL
    10 DC 4x4 TRD Sport
    5100's at 2.5, rear 1.5" AAL, rear TSB
    Lol. Nice!
  9. Feb 14, 2011 at 5:53 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    have you considered regearing for 35 or do you not mind the power and mpg loss?
  10. Feb 14, 2011 at 7:25 PM
    con3boy808
    Maui Hawaii
    Regearing is done already with 4.56. I know 33's look small and 35's look perfect but function is key.
    How it sits now...
  11. Feb 14, 2011 at 7:52 PM
    sir1123
    Charleston
    got ya what would they rub on?
  12. Feb 14, 2011 at 8:00 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i have 7.5" of lift on a 1st gen, i only rub at almost full lock, but its rubbing front leaf springs, even the 33s did that, i say go 35 (thats what im running)
  13. Feb 14, 2011 at 8:03 PM
    PWhite13
    PWhite13 Well-Known Member
    Prescott
    Southern California
    06 Silverado Crew Cab 5.3
    Isn't it a bad idea to have the Bilstein's set higher than 0" on another lift?
  14. Feb 14, 2011 at 8:18 PM
    SuthrnTaco07
    SuthrnTaco07 Well-Known Member
    Kyle
    Huntsville, AL
    2020 Cement Tundra Limited
    None
    Honestly.. I have a 6" Pro Comp lift and 35x12.50 R18 and i honestly don't rub.. EXCEPT! if i'm off cambur and/ or hit a big bump while mostly turned.. But for the most part.. Daily driving and if i take it slow on the trails then i'm ok.. I have no problems at all and i have still yet to cut my body mount... You should never really "Stack" lifts though.. Maybe body and suspension.. but not suspension and suspension.. TOO much strain...
  15. Feb 14, 2011 at 8:52 PM
    con3boy808
    Maui Hawaii
    I know you shouldn't stack lifts but do you really know why. Its not strain on parts if you know now the suspension works. If you crank adjustable coilovers on a Drop Bracket Lift are you considered stacking?
    Its the one who over achieve that jack things up. Soo not good.
    You have to get under your truck with your specific lift. For example knowing how much lift is too much for bind or excessive wear on parts. I have the option of adding lift while preventing the cv boots from rubbing, and leveling out the front from side to side due to weight on the drivers vs passenger.
  16. Feb 14, 2011 at 8:56 PM
    sir1123
    Charleston
    well with 4" and 6" and 8 " lifts it just moves the stock suspension down with brackets and longer extension so in theroy it just a longer bigger whatever u want to call it suspension so with a 6 inch you can put more lift because it would just be like a stock suspension. i say this because i know you can do it with chevy ifs so i would think the same goes with taco ifs
  17. Feb 14, 2011 at 9:07 PM
    con3boy808
    Maui Hawaii
    True .
    Also people say dont stack lifts so what about blocks and aals?
    Thats stacking.
    The leaf pack i got eliminated so many issues of that and traction issues, but in the end its works with a block aal in the rear.
    All of this depends on what type of use your truck goes through.
    alot of trial and error comes with modification.
    Each generation and product manufacturer usually differs
  18. Feb 14, 2011 at 9:22 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    What cap is that?
  19. Feb 14, 2011 at 9:43 PM
    con3boy808
    Maui Hawaii
    ^^ Soft topper
  20. Feb 14, 2011 at 9:47 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Are those rims 18x10?
