33's with 3" toytec lift?
Discussion in 'Wheels & Tires' started by zx200, Jun 20, 2008.
  1. Jun 20, 2008 at 6:57 PM
    zx200
    zx200 [OP] New Member
    Just ordered the 3' Toytec lift with aal. The wheels I have are Eagle 137 w/ 4.625 backspacing and +5mm offset. My question is will 285/75 r16 Nitto Grapplers fit with min. rubbing, does the wheel have enough backspacing to keep the tire of the upper A arm? If I need to get wheel spacers, what thickness would work the best? I saw some 1/4" spacers, but I'm not going to get them if I don't need them. Thanks, Z
  2. Jun 20, 2008 at 7:08 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    Welcome to the forum!
  3. Jun 20, 2008 at 7:08 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I don't have the 16" rims but do have the 3" toytec lift. I have some bfg 285/70/17 33" tall. I trimmed very little and removed the mudflaps in the front. My back space was 4.5" offset was 0
  4. Jun 20, 2008 at 7:12 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    They will fit, but you must [​IMG]
