33's with just leveling...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prerunner32, Jul 27, 2011.
  1. Jul 27, 2011 at 3:48 PM
    prerunner32
    prerunner32 [OP] TRD
    Alan
    Foothill Ranch
    05 Prerunner TRD Sport Longbed
    285/70/17 BFG A/T's, 17in Method Double Standard Wheels, Camburg 2.5 Coilovers, Alpine Head Unit, Infinity Speakers, 10" JL Audio Sub, 2 Rockford Fosgate Amps, AFe Stage 2 Si (Oiled)
    Havent seen a preticular thread yet about this... Is it possible to fit 33's with just leveling my tacoma with 5100's? I understand I might have to trim the bumper a little.. But as long as it is minor I am ok with that.
    The plan:
    5100's
    General Grabber A/T's 33x12.5x17
    Method Race Wheels (Black) 17x8.5
    Please, any thoughts and has anyone done this or tried before? Also pics would be a plus :D
    Thanks!
  2. Jul 27, 2011 at 4:01 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    I have a good 2.5" and i had to trim a my fender and cab mounts plus i have an offroad bumper and removed my fenders for my 33's. You will most likely need to do a lot more trimming than you would want
  3. Jul 27, 2011 at 4:07 PM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    It depends on all kinds of things -- whether or not you have TSB springs (which will determine what "level" is and what ride height setting you put the 5100's at), which tires you buy, backspace/offset, how the tires fit on the wheels, etc, etc. . If you go with 1.75", then the answer is probably no, if you go with 2.5" then the answer is probably yes.
  4. Jul 27, 2011 at 5:14 PM
    prerunner32
    Alan
    Foothill Ranch
    Dam I was afraid of this... What is the biggest tire size you can get with a 1.75in lift? I was thinking of 275/70/17's. Not usre if I want to go with 285's or 275's. And if I should go with 70 or 75... Any suggestions.
    Again sorry if this is a reacurring thread.
  5. Jul 27, 2011 at 5:19 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    Im running 33's with just a daystar spacer/ leveling kit in the front. All i had to trim was the plastic under the fender a bit.
