33s with no rubbing?
Discussion in 'Wheels & Tires' started by devilsalmostfree, Oct 30, 2008.
  1. Oct 30, 2008 at 7:15 PM
    devilsalmostfree
    devilsalmostfree [OP] Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    im about due for a new set of tires on my taco! im running 31x10.50's, i dont have a lift or anything, to me & what i use the truck for, its high enough, but im just wondering if im capable of running 33's on it, & them not rubbing? i dont use my taco as an dd anymore, so im not too worried about the gas milage, or i guess if i did decide to take it on a long trip, then i could have 2 sets of wheels & tires! let me know what u guys think! thanks, carl!
  2. Oct 30, 2008 at 7:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If your not lifted, 33's will rub.
  3. Oct 30, 2008 at 7:17 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Alot. They rub slightly with the 3" lift.
  4. Oct 30, 2008 at 8:37 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    hmm, that sux! guess ills just stick with 31's! thanks guys!
  5. Apr 22, 2010 at 11:41 PM
    astral
    astral On my second taco now....
    Arizona
    2011 TX PRO
    Where do they rub with the lift? Is it easy to trim?
  6. Apr 22, 2010 at 11:46 PM
    AZtacoma05
    AZtacoma05 Well-Known Member
    Austin, TX
    17 DCSB TRD Off Road
    Someone on here is running 33's with no lift.. you have to trim some metal and some of the back of the driver side fender I believe. I've got 265/70/R17's which come out to close to 32's and I had to remove my mudflaps and I still rub on the fender a little bit.
  7. Apr 22, 2010 at 11:49 PM
    AZtacoma05
    Austin, TX
    Oh ya and you'd probably need some wheel spacers..
