33x10.50x16
Discussion in 'Wheels & Tires' started by wilsonpj, Nov 20, 2009.
  1. Nov 20, 2009 at 9:46 AM
    wilsonpj
    wilsonpj [OP] Well-Known Member
    Pete
    Charleston, South Carolina
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    How come no one makes a 33x10.50x16 or 265x80x16?
    Seriously, wtf?
  2. Nov 20, 2009 at 9:47 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Seems like there isn't enough width and the sidewalls would have to be super stiff to keep them from flexing.
  3. Nov 20, 2009 at 9:49 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    they make a 34x10.5
  4. Nov 20, 2009 at 9:50 AM
    wilsonpj
    Pete
    2006 DC, SB, OR
    So what is the next closest tire...?
    33x11.50 or the metric equivalent?
    Putting these on stock wheels and a 3.5in lift, with TC or LR UCA's
  5. Nov 20, 2009 at 9:54 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    You'll be running wheel spacers and will most likely have to trim and reinforce your cab mounts to avoid rubbing.
  6. Nov 20, 2009 at 10:08 AM
    wilsonpj
    Pete
    2006 DC, SB, OR
    So is there a 33in tire or metric equivalent that I can run where I won't need to trim my cab mounts, I don't mind trimming the plastic but I don't want to do anything serious.
  7. Nov 20, 2009 at 10:13 AM
    tacotime05
    tacotime05 Member
    DFW
    08 pre runner dbl cab blk lifted
    OME lift, A R wheels, flip out screen, alarm remote start,
    255/85/16 it's like a 33x10.50
  8. Nov 20, 2009 at 10:14 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    you mean its like a 33x9.50 or 33x10
    the 255/85 is a SKINNY tire
  9. Nov 20, 2009 at 10:17 AM
    wilsonpj
    Pete
    2006 DC, SB, OR
    I just want a 33 in tire without having to go over 12in wide. That is all. Or close to 33 for the damn metric sizes.
  10. Nov 20, 2009 at 10:18 AM
    JimBeam
    JB
    2015 Tundra
    255/85/16 is 33 and some change tall...skinny though
  11. Nov 20, 2009 at 10:20 AM
    wilsonpj
    Pete
    2006 DC, SB, OR
    what are most 2nd gen lifted trucks running?
  12. Nov 20, 2009 at 10:28 AM
    JimBeam
    JB
    2015 Tundra
    im not sure what size would be ideal for you since youre keeping the stock wheels
  13. Nov 20, 2009 at 10:30 AM
    mjp2
    NJ
    Not 33's.
  14. Nov 20, 2009 at 10:32 AM
    JimBeam
    JB
    2015 Tundra
    with wheel spacers and those new UCAs he should be able to run 285/75 right?
  15. Nov 20, 2009 at 10:33 AM
    wilsonpj
    Pete
    2006 DC, SB, OR
    TW has way too much mixed info. I've been told too many different things from too many different people.
    Yes you can, no, maybe, your rub, you will not rub, need spacers, should be fine without them, etc....
    Too bad the people with this type of set up never chime in....
    So frustrated.
  16. Nov 20, 2009 at 10:41 AM
    mjp2
    NJ
    Don't complain about a lack of information in your less-the-1-hour-old thread. This topic has been covered to many times and that info and is always available using the search feature.
    You can fit 33's but you're going to have to do some modifications for clearance. That's the long and short of it.
    Stock wheels have 5.5" backspacing and most people run 4.5" to clear the UCAs with larger tires. If you're keeping the stock stuff, you'll most likely need spacers. You're going to hit your body mounts with that size tire. I've got a long travel setup and had to trim the mounts to fit 33.5" tires.
    The only certain way to know what's needed is to just do it.
  17. Nov 20, 2009 at 10:55 AM
    wilsonpj
    Pete
    2006 DC, SB, OR
    I've read most every thread out there and they all have mixed info whch is frustrating, but I sure as heck don't know other wise I would not be here asking. Seems like you get different info based on who replies.
    It would be nice if this stuff was more black and white or if someone had definitive info on fitments for given set ups.
    It would seem kinda stupid to buy a tire to just see if it fits they have to sell them and get a new set.
    I do appreciate all the input from everyone!
  18. Nov 20, 2009 at 10:56 AM
    wilsonpj
    Pete
    2006 DC, SB, OR
    Thanks! I plan on getting some wheel spacers 1.25in. that should give me enough room.
  19. Nov 20, 2009 at 11:00 AM
    wilsonpj
    Pete
    2006 DC, SB, OR
    I'm not sure what you are saying here...
  20. Nov 20, 2009 at 11:03 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    Does BFG still make a 255/85/16 in the mud terrain? Thats as close as you will get.
