33x12.5 Duratracs or any other 32x11.5 AT Tire?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaGus, Jun 19, 2010.
  1. Jun 19, 2010 at 9:56 PM
    TacomaGus
    TacomaGus [OP] Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    i had my mind set on getting an AT tire in 32x11.5 since they are all mostly in the same weight range since their C rated (46-48 lbs) but then i was looking at the wrangler duratracs and they only weigh 48lbs in 33x12.5. The 33's def look sweeter but i only have a 4 cyl and i was worried about too much weight and roll resistance with that size tire, but they weigh the exact same as any other AT tire in a 32x11.5 size.
    So now i'm wondering A.) whether my 4 cyl could handle these and B.) since i have the 5100's in front set at 2.5 would that even be enough to clear 33x12.5's on a rim 8 inch with 3.75 backspacing?
    and the Duratracs don't come in 32x11.5 cuz otherwise i would just make it easy on myself haha
  2. Jun 19, 2010 at 10:58 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I'm running into the same questions myself, except that I'm currently running 265/75R16s and thinking about putting on 285/75R16s on stock 16" wheels and hoping there wont be much rubbing.
    I think you're going to be out of luck with the 33's though, at least with out some new fenders. There really just isn't all that much extra room in the wheel well. With people complaining about minor rubbing with 285s, you're really going to be rubbing all over the place with the 33", even with the less backspacing.
    What I plan to do when I'm ready to buy is to just go down to the tire place and see if they'll try it on to see how much rubbing there is and if its something I can cut/bend to make it all better or not. Worst case is I just stick with the same size I have and call it good. It really is only an inch difference for me. Duratracks are pretty thick on the tread, so I'm hoping I can get away with it.
    As far as Duratracs, they have them in 285/75R16, which I believe translates pretty close to the 32x11.5. Those are the ones I've been looking at for myself, although they are the more expensive E rated tires. Duratrac goes all the way up to 315/75R16 for 16" wheels. http://www.goodyeartires.com/cfmx/web/goodyeartiresel/details.cfm?product=354 (expand tire sizes at the bottom)
    And then again, I may just be really confused, as I'm not used to the height x width dimensions for tires.
  3. Jun 20, 2010 at 8:34 AM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    You 4 cyl will handle 32s or 33s if it has the right gears. To find out visit http://www.brian894x4.com/Gearratiosanddiffs.html
    If you have 4.10s you should be fine but may notice a slight drop in power especially at high speeds. If you have gears like I did 3.58s - I would re gear.
    http://www.1010tires.com/TireSizeCalculator.asp?action=submit
    I don't think that wide of a tire will clear with factory backspacing. You may need wheel spacers or go with a narrow tire like a 33x10.50.
    But if you have a 16" rim go with something like 285/75/16. It is about a 32.75 and 11.5 inches wide. But you still may need some wheel spacers. Also will need to do the pinchweld mod.... look it up.
    Also I am not sure if you can mount a 11.50 or 12.50 tire on the factory rim because I believe it is only 7 inchs... so you may want to find that out. I think you need at least an 8 inch wheel
  4. Jun 20, 2010 at 9:31 AM
    TacomaGus
    Gus
    Morgantown, WV
    well i have 4.30 gears i found out last night by looking it up and i plan to run a 8 inch wheel regardless
  5. Jun 20, 2010 at 9:47 AM
    Dirty D
    Dirty D Member
    Boulder, CO
    02 4x4
    Bilstein HD struts and shocks Goodyear Wrangler Duratrac 265/75/16 Flowmaster 50 series delta flow
    I just recently got some 265/75/16 duratrac's load C and even with the V6 there is a very noticeable loss in power over the 265/70/16. I am also up in Colorado so driving up to the trails at 9,000 ft does not help either. I have no personal experience driving the 4 banger but I imagine those 33's would make it a complete slug without a re-gear.
    Wheel spacers are going to be a necessity with that wide of a tire. Check out Spidertrax.
  6. Jun 20, 2010 at 10:03 AM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    I like the 32 inch dynapro mt's they are sweet and get great reviews
  7. Jun 20, 2010 at 10:27 AM
    toycar18
    Colorado
    98 Reg Cab 2.7L
    4.30s are perfect for a 32s or 33s.
  8. Jun 20, 2010 at 8:09 PM
    pmbazus
    pmbazus Well-Known Member
    AZ
    2015 TRD Sport 4WD
    Kumho KL78 AT 32 11.50 15. I have Bistein 5100 set at 2.5". ProComp 8069. Tires are great and inexpensive. Onlinetires.com or Tirerack.com.
  9. Jun 20, 2010 at 9:15 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    Hello Boulder brethren
    :wave:
  10. Jun 20, 2010 at 10:40 PM
    TacomaGus
    Gus
    Morgantown, WV
    gonna be in CO in a week for a month long stay. I have worked at a ranch in McCoy for the past few summers and i'm just going out for a month this summer. Some of the money earned will be going towards these wheels and tires haha
  11. Jun 21, 2010 at 9:07 AM
    Dirty D
    Dirty D Member
    Boulder, CO
    02 4x4
    Don't get me wrong these tires are awesome! They are about as close to a mud tire as AT's come, but they for sure are heavy and run a bit larger than other manufacturers tires. Have fun in Colorado, the wheeling out here is great.
    If you are already in Colorado you could stop by Spidertrax and pick up some spacers, they have some blemished ones going for 80 bucks.
  12. Jun 21, 2010 at 10:04 AM
    AlexanderD
    AlexanderD Well-Known Member
    Alex
    whitby Ontario
    03' tacoma 4x4 trd step-side
    will he really need spacers if he is running a non-stock wheel with 3.75" of back spacing?
  13. Jun 21, 2010 at 10:26 AM
    Dirty D
    Dirty D Member
    Boulder, CO
    02 4x4
    Probably not, I forgot about that.
  14. Jun 21, 2010 at 12:21 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    I have 31 inch duratracs with my 2.7l i upgraded from 215's and barely noticed a difference execpt at highway speed the rpm sit much lower in 5th gear. i LOVE THEM AND THEY LOOK SOOOO SEXXY!!!!
  15. Jun 21, 2010 at 3:13 PM
    81CountryGirl
    81CountryGirl Member
    Kate
    New Brunswick, Canada
    '01 Tacoma 3.4L 5Gear 4x4
    2.5" lift
    I'm running 285/75R16 MTs now on a stock 4 Runner wheel (on my 01 Tacoma). The truck's got an add a leaf in the rear and 2.5 inch blocks on the front springs and the drivers side front tire rubs the frame a tiny bit when the wheel is cut all the way. I also trimmed a very minor amount of the plastic inner fender at the back outer edge because it was rubbing there too. Funnily enough, that's the only wheel that rubs at all tho. You soon get used to the full cut problem and just don't do it anymore. Hope this helps!
