33x12.5 on stock?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mizzac, Nov 30, 2010.
  1. Nov 30, 2010 at 9:17 AM
    mizzac
    mizzac [OP] Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Can I run a 33x12.5 on my stock 15's? The guys at my tire shop seemed to think it would be fine with my 3in lift, but Ive been reading up and I have heard both sides that it will work fine jsut rub a little on the wells, or that it wont and it wil rub my stock UCA or will be dangerous and have to be run at a lower psi. Im really hoping not because I am getting a good deal on them and the lift goes on Thursday.
  2. Nov 30, 2010 at 9:20 AM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Look up tires on tirerack.com and it will tell you rim widths
  3. Dec 3, 2010 at 3:52 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    yea they are a little wide..
  4. Dec 3, 2010 at 8:05 PM
    '02TRD
    '02TRD Well-Known Member
    Portland, OR
    2002 Tacoma Xtra Cab 4x4 SR5 TRD
    Billstein 5100's & AAL, 285/75R16 Toyo Open Country M/Ts on Black 16x8 Raceline Renegades, Pro-Tech Toolbox, Wet Okole covers, K&N air filter, Tow package, Alpine digital media receiver, Kenwood Amp, Rockford Fosgate 10" sub, Cobra 75 hand held CB, front differential drop
    different offset wheel or skinnier tire
  5. Dec 3, 2010 at 8:08 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Just get some spacers
  6. Dec 3, 2010 at 8:18 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Not sure a spacer is the way to go in this case. A stock rim is 6", 7" wide at best. Way too narrow for 12.5" wide tires. I think most manufacturers recomend a 9" minimum.
  7. Dec 3, 2010 at 8:45 PM
    kinkrider101
    santa barbara
    wheels and tires
    Ya just thought about that haha
  8. Dec 4, 2010 at 11:07 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    You can run 12.5" wide tires on 8" wheels no problem. Did that for several years on my old Cruiser.
  9. Dec 4, 2010 at 9:00 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    I think it will rub at least some without spacers. I have 32x11.5 on OEM alloys with a 2.5" lift and they barely rub with the wheel all the way turned, but any wider tires would def rub.
  10. Dec 5, 2010 at 6:14 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
    I ran 33x12.5's on my jeep with 15x8 rims for years. Perfect size combination.
    I ran with 32X11.50's on stock 7" wide rims for years (on my 96 tacoma) - but I had to run with the air pressure about 5lbs less than normal to ensure the tread would wear evenly. If you don't, you'll wear out the center of the tread.
    If you run 12.50" tire on 7" wide rims - I can honestly say, it'll be UNSAFE. You'll have to lower the air pressure even further to get proper tread wear. I'm really really surprised a shop would even mount that size tire on that size rim.
  11. Dec 5, 2010 at 6:44 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    If you are deadset on the 33x12.5's then you might want to try rims from an old GM 4x4 87 or older, that should solve your offset problems and lots of those rims were 8" wide, just keep an eye out or go to your local recycle center.
  12. Apr 6, 2016 at 10:26 PM
    Tacoinnovation808
    Tacoinnovation808 Well-Known Member
    Ajolo
    I am also having this issue in my 3rd gen tacoma, i recently lifted it with 3 inch leveling kit and i wanna get bigger tires, just like u i got a pretty good deal on 33x12.5 bajas and i am planning to mount them on my stock rims. I know they will rub on the UCAs so i bought me some 2 inch wheel spacers
  13. Apr 7, 2016 at 10:12 AM
    99kyota2506
    99kyota2506 Well-Known Member
    EO
    1999 Taco/Flatbed
    Get to it later...
    Just get some 10" wide wheels, problem solved and no shitty spacers...I run 33x12.5x15s and barely rub at full turn.
  14. Apr 7, 2016 at 11:45 AM
    Tacoinnovation808
    Ajolo
    I dont really wanna buy new wheels, i kinda like the stock rims for now
  15. Apr 7, 2016 at 12:13 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    96 extended cab sr5
    cxracing turbo, fic6, methanol injection, 5100s/eibachs, skyjacker leafs, rear 5125s, no-slip rear locker, 35" grabber x3, magnaflow muffler, throttle body spacer, retrofit headlights, trans cooler, bed lined exterior, excessive stereo etc...
    They wont work on stock 7" wide wheels.
  16. Apr 7, 2016 at 1:22 PM
    99kyota2506
    EO
    1999 Taco/Flatbed
    Get to it later...
    31x10.5 is about your best bet then with stock wheels, maybe a 32x11.5
  17. Apr 7, 2016 at 3:05 PM
    Northern Taco
    Northern Taco Well-Known Member
    I know my factory 15" wheels with my 31x10.5 bulge out quite a bit (looks good IMO) can't imagine a 12.5" wide tire on them though.
