33x12.5 on stock?
Discussion in 'Wheels & Tires' started by mizzac, Nov 30, 2010.
  1. Nov 30, 2010 at 9:41 AM
    mizzac
    mizzac [OP] Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Can I run a 33x12.5 on my stock 15's? The guys at my tire shop seemed to think it would be fine with my 3in lift, but Ive been reading up and I have heard both sides that it will work fine jsut rub a little on the wells, or that it wont and it wil rub my stock UCA or will be dangerous and have to be run at a lower psi. Im really hoping not because I am getting a good deal on them and the lift goes on Thursday. I looked at tirerack trying to figure it out but still cant, I just dont understand tire spacing or any of that stuff enough.
  2. Nov 30, 2010 at 10:12 AM
    98tacoma27
    Ben
    Not Beech Creek
    IIRC, they will hit the UCA. You cannot run them on stockies without spacers.
  3. Nov 30, 2010 at 10:13 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    spacers required
  4. Nov 30, 2010 at 11:00 AM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Wont that look wierd being they are so wide? would it be easier just buying a different rim?
  5. Nov 30, 2010 at 2:12 PM
    98tacoma27
    Ben
    Not Beech Creek
    It would be the same effect.
  6. Nov 30, 2010 at 2:18 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    ok I have made a list of possible tire sizes
    Tires Diameter Width
    31/10.5/15 30.98" 10.51" Stock
    285/75/16 32.83" 11.22"
    285/75/15 31.8" 11.22"
    33/12.5/15 33.03" 12.52"
    295/75/15 32.42" 11.61"
    305/75/15 33.01" 12.01"
    Would any of these work? I really dont want to buy spacers right now, or new rims.
  7. Nov 30, 2010 at 2:22 PM
    98tacoma27
    Ben
    Not Beech Creek
    Try a 255/85-16
    33" 10.04"
    They 31-10.5 is a stock size so you won't have an issue there
  8. Nov 30, 2010 at 2:25 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Ya I knew it stocks would fit i was just using it as a comparison.
    So basically nothing will work without spacers or rims?
  9. Nov 30, 2010 at 2:30 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Or we could just rig the shit out of your wheels... Grinder here we come!
  10. Nov 30, 2010 at 2:31 PM
    98tacoma27
    Ben
    Not Beech Creek
    The 255's will and 265's should also.
  11. Nov 30, 2010 at 2:45 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Or trade me your wheels, probably still wont work but I'd like some 16s.
    and if I go 265/85 or 255 as you were suggesting wouldnt I still need spacers, or new rims such as 16s?
  12. Nov 30, 2010 at 2:49 PM
    98tacoma27
    Ben
    Not Beech Creek
    New rims for the 16's = yes
    Spacers = no
    Or you could do a 33 10.5 15
    Get your height, a decent width and no need for new rims.
  13. Nov 30, 2010 at 2:53 PM
    Snoyota
    Snoyota Well-Known Member
    Taylor
    Marin County, CA
    07 Black Dbl Cab Sport
    3" King coilovers with resi, king rear shocks with resi, ome dakar leafs, 4xinnovation kickout sliders, CBI front bumper, warn M8000 winch K&N filter. Pioneer deckplate with 500w alpine amp and 13" Focal Sub
    I had 33x12.5 on stock, fit fine. I have 3in lift with TC UCAs
  14. Nov 30, 2010 at 11:23 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    I keep hearing it will fit and it wont Im kinda worried about buying the wheels and them not fitting..maybe I can get them to try them on for me.
    Found someone with a 1st gen stock 16, would those work with like 285/75/16? or would it still not work cuz its the stock rim?
  15. Dec 3, 2010 at 3:45 PM
    phidauex
    phidauex Well-Known Member
    Sam
    Boulder, CO
    '96 4x4 V6, manual, 201k
    Small lift and a topper!
    It will work, in the sense that it will be able to be assembled. However, if anyone is telling you that 33x12.5s fit on stock suspension, they are either lying, or are able to put up with a lot of rubbing. If you only drive on the street, and gently, then you would be fine, but there is no way that tires that size will handle any compression without hitting the UCA, cab mounts, etc.
    Just remember that tires don't REALLY fit unless they don't rub during any steering position, at any suspension compression position. Anything less than that is not really "fitting", and the amount of hassle and rubbing people will put up with varies greatly.
    -Sam
